Question about E-Machines eMachines Desktop PC
Need a manual for a t3604 emachine
I have an emachine t3604 which is not turning on just has 3 beeps which apparently is a RAM problem. I can't find the manual that goes with it to check how to reset the RAM could you give me a web site I can download the manual from?
Posted by barbara_gree on
Anonymous
    Scholar:
  • 75 Answers
In that manual you cant get sir i will help you to reset the RAM . yes you are correct if you get 3 beeps the problem is exactly with your RAM only do you know to remove side cover of your machine if you know means proceed the following " there will a green colour chip which fixed vertically in your machine that is called as RAM the RAM is locked with the help of two white coloured notches which is at the both ends of the RAM the inserted picture is the RAM , you have to release that notch in upward direction hardly so you have to do it on both sides after that the RAM chip will be separated, and then take the RAM separately and rub the golden colour contacts usings a ERASER and then again fix it by watching the small cut in the RAM so that it will fix firm and you should press the RAM hardly to lock the RAM inside the slot and also the white color notch should be closed. try this you will find solution definitely sir thank you.need a manual for a t3604 emachine - bd6f836.jpg
Posted on Oct 18, 2009
T3604 motherboard diagram for front panel.
get the user manual and it will provide you all necessary information.
download it from here,
http://www.retrevo.com/support/eMachines-T3604-Desktops-manual/id/4870bh045/t/2/
best of luck!
2helpful
I attempted to add a secondary hard drive, did so, truned it back on and got 3 long beeps, no monitor action, removed the secondary, turned it back on w/ the original that hadnt been moved and still got...
3 long beeps means that there has been memory failure. You may have accidentaly knocked your memory sticks out of place when you opened up your computer. Try taking them out and putting the memory sticks back in, this should fix your problem.
Also, please leave me 100% votes, thanks.
My emachines t3604 starts up and all the fans are running but doesnt boot up and keyboard and monitor are not working. Replaced the ram but that doesnt work any ideas.
Try downloading puppylinux, burn it onto a cd then boot from the cd, if everything works fine, then you need to reinstall windows.
2answers
Need video driver for Emachine T3604
I'd suggest deleting the existing video driver and then reinstall.
1helpful
3answers
Emachine t3604, computer shut down. then restarted showing hard disc error and it never started again. the only thing that shows when booting is the e symbol with f2 or f10 options for Bios. then it goes...
I'm sorry to say this but your hard drive may be faulty and need a replacement. Your files might still be retrievable but you will need to take it to a repair center to get it retrieved or plug it as an external hard drive and try to retrieve data yourself. But nevertheless, it seems like your hard drive gave in and will need to be replaced with a new one..
Thanks,
Lolita
7answers
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
