Question about Philips Magnavox 51MP392H Rear Projection Television
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
    New Friend:
Picture is red
Posted on Jul 25, 2011
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 18, 2009
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
Oct 11, 2013 | SNK Magnavox 42MF231D 42 in. Plasma TV
Older 52 inch tv magnavox where screen is too bright or how to repair it
There two possible things based on your description.
Go to a channel that is in black and white and examine the picture--is it black and white or yellow?
These sets do have screen controls that can be adjusted but they rarely need it.
If the picture is yellow looking it could be interpreted as too bright.
If good black and white picture---stand back ten feet when you examine it---I can tell you how to adjust the sceen controls, not real easy but can be done with someone to watch screen.
I am here to help you and I have over 30 years experience with all kinds of TV sets.
Is black and white picture somewhat YELLOW LOOKING?
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT know rate this solution as very helpful as I do this here for free.
If you have more information or need help comment here to this solution.
REGARDS, SD TECH
Aug 13, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a 52 inch Magnavox LCD tv. Yesterday the screen went black **** sound is still good. I started smelling a burnt plastic smell so I unplugged from the wall. What could be the problem?
Tv turn on now,have a flashes of picture a few sec.than dies have sound left only?Yes.The 2 long board call the LCD inverter board are dead.These 2 long LCD inverters help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jun 01, 2010 | Philips Magnavox 52MF437S/37 52 in. LCD TV
My sylvania lcd tv screen went white and still has sound
Hi taralee? my tv did the same thing last night. can you tell me what you found out? can it be repaired? thanks
Aug 23, 2009 | Televison & Video
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Philips Magnavox 51MP392H Rear Projection Television Logo
244 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
