To turn on Scroll lock you will need to press and hold the FUNCTION Key (FN), this is located beteween the Left CTRL key and the Windows key.
With FN Held you then need to press the F12 key on the keyboard, this will enable scroll lock.
just repeat the process to turn it off
quick keys:
FN + F11 = Num Lock
FN + F12 = Scroll Lock
SOURCE: I use toshiba satellite A305-S6872 laptop would not load OS
you will most likely have to go into the recovery console to fix the problem or even re-install.
The other two solutions are to either boot up in safe mode to correct the problem by trying to revert back to a saved well working time, or take out pci cards and reboot always taking out another pci card until you find the problem.
if nothing works, re-install or fix in recovery console. <<< or >>>
BEST Solution
at re-install, choose repair windows.
isn't the Scroll Lock key on the Function row of keys, on the right hand end?
