Question about Apple iPhone 3G
Iphone will not restore error 13 - Apple iPhone 3G
    Scholar:
  • 117 Answers
You can resolve the restore issues using the troubleshooting steps found in this document:
1. Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and check for updates.
  • Windows: Choose Help > Check for Updates
  • Mac: Choose iTunes > Check for Updates
If there is an update to iTunes available, install the update and try to restore again. If you do not have an active connection to the Internet, or your Internet security settings are configured to prevent iTunes from communicating with Apple, iTunes will alert you that the iTunes update server could not be contacted. Resolve your Internet issues and attempt to update again.
2. Restart your computer
Simply restarting the computer can clear up certain issues that could prevent you from restoring iPhone or iPod touch. After you restart, try restoring the device again in iTunes.
3. Open the proper ports and allow access to Apple servers
During the update and restore process, iTunes needs to contact Apple. Ensure that your computer has the following ports open and can access these servers:
Port 80
Port 443
phobos.apple.com, albert.apple.com, gs.apple.com
If you see "Error 9807", you must open access to the following VeriSign servers:
evintl-ocsp.verisign.com
evsecure-ocsp.verisign.com
If you are using a Windows operating system, you can follow this article to help resolve issues caused by third-party security software.
You may need to update, properly configure, disable, or uninstall built-in firewalls and other security software to prevent interference with iTunes. For assistance with this, contact the company that supports the firewall or security software you use. If you are using proxy settings, try to restore or update without using a proxy.
4. USB Troubleshooting
Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built in to the computer are preferred over a hub. If you tried connecting iPhone or iPod touch to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If the issue continues:
Remove all USB devices except the keyboard, mouse, and iPhone or iPod touch. Remove all USB hubs and connect directly to the computer.
Connect iPhone or iPod touch directly to the included USB cable, bypassing the dock.
Restart the computer.
Try to restore the device again in iTunes.
If available, test with alternative, known-good USB cables.
5. Restore on a different computer
If the issue is not resolved with the above steps, try to restore using a different computer. Ensure that the computer you use has USB 2.0 ports, the latest version of iTunes, and that you connect directly to the computer.
If another computer is not available, proceed to the Advanced Steps below.
Posted on Jan 22, 2010
6ya staff
SOURCE:
How do i fix my iphone? it has itunes logo and usb pic on screen and wont system restore it says error code 1015
try a thing called tiny umbrella (http://thefirmwareumbrella.blogspot.com/) what u do is u download it ( make shore you're flash player , java and all that stuff is up to date). 1.then plug your iphone in leave itunes open and click on your iphone name in the left corner of the tiny umbrella screen . 2.then is should say on the screen start tts server click that then click exit recovery mode click that then leave your iphone then eventually it should pop up on itunes. 3. then restore your iphone from its last none back up.
sorry if the spelling is bad Iv e got dyslexia and Im 13 years old hope it helps :)
p.s. if this is wrong and u have a windows computer get a download called ireb from http://ih8sn0w.com/index.php/products/view/ireb.snow
Feb 25, 2011 | Apple iPhone 3GS Black (16 GB)
My iphone cracked about a few months ago and a few days ago i spilt water into the crack. It started with my ringtone not working and then my phone completely shut off. I tried restoring it on itunes but...
No, it's not the end but you will most likely need to take it in to a Authorized Repair Center so they can repair the broken, cracked screen and any internal damage since obviously water or moisture getting inside is an issue.
Jun 09, 2010 | Apple iPhone Smartphone
My iphone shut off and is asking me to restore it through itunes. itunes is saying an unknown error ocurred (13). and will not restore my phone.
download a thing called blackra1n google it and then and then its gonna say make it ra1n plug your iphone in and then it showd fix ok
Jan 02, 2010 | Apple iPhone Smartphone
When I was trying to resore my Iphone it says
Hi ,after searching all over the internet and posting on every forum possible i didn`t find a real answer well it seems to be a rare problem but critical. Don`t get confused by this noobs that they just post "to be in business" ,here are some tips that confused me as hell like changing the motherboard of my iphone and battery and i saw very much of you did the same way after tryed all my tips here and no result... and that are...restoring in dfu mode or recovery mode, tryed all versions of itunes,hard reset,adding the source 74.208.10.249 gs.apple.com in the file C:\WINDOWS\system32\drivers\etc\hosts,reinstall windows xp ,vista, 7 eaven on iMac,tryed with iReb NOTHING WORKED...but don`t panic and don`t replace anything at your iphone because it must be released a bootrom update in 2-3weeks and that should solve all the iphones troubles.Good luck cya i think this will help a lot with error 13:D
Oct 29, 2009 | Apple iPhone 3G
Can someone help with a error code 13 for my iphone...I have uninstalled itunes restarted computer installed itunes..went to restore phone now i have code 13 again
hi..The reason to this problem could be a hardware failure
causing the hard drive not to boot properly or the software
needs to be reinstalled again.
check it out..
thank u..
kindly rate my response..
May 14, 2009 | Apple Cell Phones
try respring it (central + power buttons together and then connect to iTunes in safe mode,choose full restore (it will erase everything but if you have back up can be restored).
May 12, 2009 | Apple iPhone 3G Black Smartphone
Iphone 3g error 13
Hi friend:
Don´t use front USB hub from computer.
Try rear USB ports.
If you are using laptop, try on diferent computer.
Regards
Aug 19, 2008 | Cell Phones
Can't Restore iphone
Well since you have and unlocking iPhone software you can restore your iPhone because the factory settings of the origanal iPhone have been removed.
Thank you, Apple Care Technical Support
Jul 03, 2008 | Apple iPhone Smartphone
Try restoring in DFU mode, which is different than recovery mode. I happened to stumble across it while trying to restore an iPhone 3G that a user unplugged in the middle of the 3.1 update. It kept showing an error of 1611 or 13 and wouldn't restore in recovery mode. I found this DFU mode option and the restore worked fine. The DFU mode keeps the iPhone OS from loading, so you don't run into as many compatibility problems. Go into DFU mode, then try restoring the phone and see if that works.
http://techierambles.blogspot.com/2009/09/restore-iphone-with-error-13-or-1611-in.html
To enter DFU mode:
1. Connect your iPhone to your computer
2 . Turn iPhone off. You may have to hold the power and home buttons down together to force the phone off
3. Once the phone is off, hold the power and home buttons together for 10 seconds exactly
4. After 10 seconds, release the power button but keep holding home until the computer recognizes that a USB device was plugged in
5. iTunes should detect your iPhone correctly, and also allow you to restore to the factory default settings
Mar 02, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
1,316 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
