MY VS-45607 wouldnt turn on. Checked fuses on power supply board OK. Plugged in and smelled smoke - burn marks on the middle of power supply board. Where can I get a new power supply board?
SOURCE: Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
SOURCE: sound but no picture on a Mitsubishi VS-45VA2.
This is the VZ1 Chassis.. CHECK FOR 1200 VDC AT PIN 1 OF CONNECTOR "DK". IF LOW OR MISSING CHECK R5D9 100 OHM 1/2 OFF PIN 1 OF THE FLYBACK ON THE MAIN PCB. 2. CHECK IC401 PIN 8 FOR 28 VDC IF MISSING CHECK R510 1.2 OHM 1/2 W OFF PIN 5 OF THE FLYBACK. IF OPEN IC401 PART # 272P239 If those voltages check out let me know and we will go to the next level. Two other questions do you have video through the pip with the alternate input? and do you have on screen display when you push menu on the remote?
SOURCE: Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
SOURCE: Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
SOURCE: The picture on my Mitsubishi Model VS-45607 is not
Good Day,
It sounds like you have a bad cap or IC. Replace C2P05 100 ufd 16 volts, off Pin 3 of IC2P01. It is on the Signal Board. IC2P01 Part # 270P466020 (stand-up type mounted on heat sink). The Signal Board is the the board on the left hand side looking at the TV from the back. The parts are on the right side of the Signal Brd towards the middle and back. Replace it even if it checks good. Look at other Caps in the general area and if you see black stuff on the negitive leg of those caps(replace them also).
Good Luck, Big Irish.
