Symphonic ST419E TV Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a symphonic wf2702..don't have original remote..trying to install nintendo wii..need vido audio input select..i am using a standard cox cable remote..i don't know what channel to set the tv on ..yikes..help!
relojmesa
Level 2:
  • Expert 84 Answers
  • Posted on Oct 17, 2009
relojmesa
Expert
Level 2:
Answers
84
Questions
Helped
24091
Points
191
AV button on tv remote or video remote
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Although the wii is turned on, there is no picture on the television. Was fine before but not working now.
Make sure that your in the right input of your television. teh defaut cable of nintendo wii is a component cable..if youre using that cable then try to change the input of your tv to component input by using the original remote of your TV.
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
No game system listed in the select key option
Some tv's (RCA) you can hit 00 on the remote and get into the aux. input menue. The wii will be a composite input source.
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
2helpful
3answers
No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
No tv remote
Go to Radio Shack and get an universal remote control, mine is a Phillips Universal and just program it to your tv. It has a tv/vcr input to let you switch to the right "input"/channel.
Codes for tv
usually the universal remote comes with a code book. if you're TV is not on it the remote won't work. But most TV's are on there. If you can't find the TV, go to the ORIGINAL COMPANY of the TV. (RCA, Samsung, etc.)
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
