well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
the db1215 that i have does have a clock....
press disp to display the clock,then release.
press and hold disp for 2 seconds, the clock will begin to flash.
press tune<< to adjust the hours and tune>> to adjust the minutes.
clock settings will be saved after 5 seconds
you need to get a wiring conecter kit. the directions will be in the box. i just got mine today and had to get one of those kits... walmart has them =P
