Question about Bulova Watch
Trying to date a Bulova mens watch
The number on the back of the watch is 7696969. There are no letters listed. I have not had the watch opened to see if any more information in engraved inside.
Posted by ddavis5131 on
Anonymous
    Sniper:
  • 61 Answers
Short of going to a Bulova Dealer for a more accurate answer; I would say the watch looks less than 10 years old.
Posted on Oct 17, 2009
I648725
Since the 1950s Bulova has used a 2 digit date code, usually on the back below the serial number. The letter is the decade (L= '50s, M='60s, N=70s, etc.) and the number is the year. For example, a Bulova with a date code of M3 was made in 1963, one with N0 was made in 1970, and so on. Prior to the 1950s, it's more complicated.
Jul 18, 2014 | Bulova Accutron Watches
I have a vintage Bulova watch that I'm trying to date: No. On face is 23 Number on back of case is 312171 I would appreciate any help.
Bulova began using a series of codes in the late 40's to date watches, look on your case for a letter followed by a number,the letter designates the decade,A=40's,L=50's,M=60's,.N=70's,P=80's,T=90's and the following number designates the year, an example would be,M4 would indicate 1964. Hope this helps,the serial numbers are used for identification purposes only
Sep 29, 2011 | Bulova Watch
Trying to date vintage Bulova ladies 17 jewel watch Swiss movement. The code stamped on the back of the watch is W80701
The best people to consult is the manufacturer.
Go to http://www.bulova.com/contact/contact.aspx (click on this link) and you will see a number of contact address.
Contact them and I would expect them to be able to dig out the information you require.
Mar 08, 2011 | Bulova Watches
Please tell me where the serial and model numbers arre on a Bulova marine Star 100m. men's [email protected]
Most of the time you can find the serial and or model number on the first link that is attached to the case of the watch on the back. Often there is a serial number on the back of the case itself. If not in any of these locations you may have to open the case and look on the inside of the case. Be careful with opening case, if you're not comfortable opening the case yourself take it to a reputable jeweler.
If there are no serials on the watch it is probably a knockoff or replica.
Hope this helps.
Feb 27, 2011 | Bulova Marine Star 96G30 Wrist Watch
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
How can I date a bulova
Visit original site here:
http://bulova.ch/brands/bulovaint/bulovaint.aspx
The rest depends on you and useability of the site.
Rate me, please.
Mar 27, 2009 | Bulova Men's Watch
I have a Bulova Caravelle mens wrist watch case number C877548. I have to replace the battery but I can't figure out how to get the back of the case off. Thanks
Hi. If you take a tiny screwdriver (one that you might use to screw a screw into an eyeglass and run it gently around the back you will feel an indentation where you can insert the tip and pop open the back. The battery is easy to access but trying to get the back back on is the problem! Good Luck.
Sep 11, 2008 | Bulova Watches
Bulova Watch Logo
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Lisa Christine
Are you a Bulova Watch Expert? Answer questions, earn points and help others
