Dual XDMR-7700 CD Player Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just put in a radio in my 88' truck and i have to reprogram my stations every time i start my truck,why is it not holding memory?
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Oct 17, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
0
Helped
23558
Points
189
Your red memory wire is not hooked up or you switched the red and yellow ignition wire around and your radio stays powered up when you turn off the ignition.
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Lock ion a radio station
TO PROGRAM THE MEMORY BUTTONS
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
The radio buttons on 09 altima are not responding when u try to change to a new radio station and to cd or radio plus when u put the cd in u can't skip to the next song
First impression is you radio is toast. It maybe some component gone bad on a circuit panel inside the radio. Before you consign it to the deep try "rebooting" it. Most electronically controlled radios have some king of logic and memory boards in them ...so treat your radio like your computer when it starts misbehaving. To reboot the radio disconnect the battery (remove the black/negative lead first then the positive/red lead from the battery), put the key in the ignition and try to start the car (it won't of course but this is to discharge any holding capacitors) and turn on the radio ...again to discharge any holding capacitors. Turn everything off and let it sit overnight if you can. Reconnect the battery. The radio should have lost all saved information (time, stations, EQ settings etc) and may now be responsive to button inputs. If this doesn't work then I'd say the radio is a goner.
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
1990 olds 88 royale
There are usually 2 fuses on a radio but one holds the memory and the other turns on the lights and amplifier. You likely blew the ic or transistor that does the amplifying.
I have and older unit a pioneer VSX 3800, how do you program the radio channels, is there a manuel for these unit i can get sent to myself
Hi.
You have a digital display pioneer receiver and you would like to know how to store radio stations.
  • first tune your radio to your selected radio station
  • next see if the receiver has a button marked memory, and it should have buttons marked 1 2 3 4 5 6 etc
  • After you have tuned in to your selected radio station, if it has a button marked memory,
  • Press the memory button, then press and hold 1 for a few seconds and that should store your selected radio station to preset 1
  • Next, tune in to another radio station and store it by pressing memory then 2 and that should store it in location 2.
  • If your Receiver doesn't have a button labelled memory, and simply has the store 1-6 etc buttons then ,
  • Tune in to your radio station , then press and hold 1 for a few seconds, it will probably flash a few times until its stored in that location 1
  • Next, tune in to another radio station, then press and hold 2 and that should store it in location 2.
  • repeat.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
2answers
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Truoble programing radio stations.
it sounds like the memory wire isnt connected to the correct position the memory wire on the stereo needs to go to b+ also a faulty battery can cause this even if the battery can still start the car. an auto electrician should be able to test the battery for free to eliminate that as the problem
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
Top Dual Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
