Facebook homepage not loading correctly - only recognized if I make it https:// and not http:// but the home page links within facebook will still fail when I try to go from an application to my home again. How do I get my browser to recognize facebook as a secure server all the time? IE8 is used on Vista. Is this some kind of ISP blocking thing to cut down on bandwidth and page hits?
You shouldn't be accessing facebook through HTTPS. Try adding facebook to your trusted zones by clicking "Tools", "Internet Options", select the "Security" tab, click on "Trusted Sites" with the green check mark, type in "*.facebook.com" without the quotes and uncheck the box toward the bottom of the dialog. Now click add and you should see *.facebook.com in the list. Click "Close". Now click on the "Privacy" tab, and move the slider down to "Accept all cookies" Click "Apply" then "OK". Try facebook again.
Let me know if this works! :)
Please vote on my solution :D
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out
internet search facebook login
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site
hope this helps
when you get requests to access any or personal information of your profile you should see who is asking and who will have access to it once you click yes all of your information can be accessed by?????
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred homepage browser
http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html
Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal...
Hope one or some of these will help you
Does not work here
