Question about Jabra Cell Phones
GNM-OTE3 Jabra Bluetooth Headset is blinking 3 times and I am trying to pair with my cell phone but it fails each time
Posted by jpjagreene on
Anonymous
    New Friend:
Have you already tried to put your headset in pairing mode first? Anyway, to do it, starting with it turned off, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone'sbluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros);
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Posted on Jan 01, 2011
  • noble varghese Oct 26, 2011
    thak you very much it now works :D
I have a Jabra Clear that won't match up with my phone
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Nov 11, 2014 | Jabra Products - BT2080 Monaural...
I have a Jabra GNM-OTE3 and I cant connect it to my Motorola i776, I all ready try holding for 5 seconds the answer button and the power button, but still cant read it my Motorola. What can I...
I can confirm that the headset works. Suggesting two steps:
1) Confirm that you are holding both the power button AND the answer button for at least 5 seconds. When you release both buttons, the light will go on steady. Does the light go on steady? (If not, you may have a headset problem.)
2) Turn on bluetooth on your phone. Then "search" for the (now with light on) headset. (If the light is off, repeat step 1). The moto should discover the headset, and connect. It may prompt you for a pin...and the default pin code is 0000.
Hope that helps. dw
Dec 27, 2010 | Jabra Bluetooth Headset with Adjustable...
I'm trying to pair my Jabra GNM-OTE3 with my laptop. Devices not finding it. Can I get a driver?
Hello sir, honor to make you know that GNM-OTE3 is not a valid model of jabra products. try to identifie your product first you can post a photo for it and I can help you in the future. Bye
Oct 29, 2010 | Sony Computers & Internet
I hav a jabra bluetooth....type ote3 and i lost my directions for connecting it to my phone. i hav a samsung gravity phone i went to settings under bluetooth and turned it on and searched for devices but...
1. Put the headset in pairing mode and make sure that the headset is on. To do this: Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for a code to pair with it, the code for jabra headsets is usually 0000
Sep 02, 2010 | Cell Phones
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
How do you put a Jabra GNM-OTE3 in discovery mode?
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Dec 20, 2009 | Jabra Bluetooth Headset with Adjustable...
Cell Phones Logo
4,715 people viewed this question
Top Jabra Cell Phones Experts
Anthony Ward
Anthony Ward
Tom Chichester
SANTHOSH
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
