I have a Kohler Command 17.5 model# CV491S. It will not start and violently backfires through the carburator and exhaust. Is this a timing issue and if so how is this fixed?
https://www.kohler-engine-parts.opeengines.com/.../free-kohler-service-...Kohler Engines and Kohler Engine Parts Store Free Kohler Service Manual Downloads - Listed below are Kohler service repair manual in Adobe PDF format ...
technically it is possible to do a heart trnasplant
all you need to check are the mounting flange holes or be able to drill new holes in the mower frame
and next the method of attaching the drive pulley or pto to the crank shaft has to be considered
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
