Question about Exercise & Fitness
Need to dismatle to move and can't
We need to move our treadmill upstairs and can't disassemble to move upstairs
Posted by dawn_winrow on
Anonymous
  • 40 Answers
There are a lot of different treadmills and stairways that require specific solutions, but there are some general solutions.
You say you can't disassemble it, so try forearm forklifts, they can make a 2 person lift very manageable. Also if you have a large piece of cardboard (and once again, 2 strong people) the cardboard can be used to both provide a surface that will slide up the stairs and distribute the weight over a larger area, so you can actually put it on it's side without causing damage.
I've used this technique and it works with a little caution and muscle.
Posted on Oct 25, 2009
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
Mar 06, 2015 | NordicTrack Exercise & Fitness
What is the easiest means of partially disassembling and moving an Epic 35 Treadmill?
1) is more easy to fold 2) However if the place is impossible to move you must disassemble the treadmills read your owner manual or download from www.fitness.manualsonline.com see the video attached.
God bless you
Oct 08, 2013 | Epic View 550 Treadmill
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
Reebok fusion rower manual-how to operate the electronic display
I have recently bought from a friend a reebok fusion treadmill. However due to a break up the treadmill was dismatled and put into storage and now they cannot remember where the wires go. Can anyone help?
Oct 15, 2011 | Reebok New York Giants Eli Manning Jersey
I just moved my cadence 200cs treadmill, it was running when I moved it, Now I can not get it to move the belt., could it be the fuse and how do you take it out and look and what kind of fuse
hi
just look where power cable connects to the treadmill there is one fuse 15 amp it could poped just press it back
also check the console cable if you disassembled it
Nov 22, 2010 | Cadence Weslo 200cs Safety Key...
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Aug 10, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
Need to move treadmill downstairs and can't fold and secure it
Typacally heavy movers will use pallet wrap, which is industrial size and strength plastic wrap, this is available where ever moving supplies are available. (UHaul, Truck Rentals, or storage facilities.), fold up the machine and wrap it well with the wrap. This will also protect the machine, and the walls as it should prevent paint transfer on those slight OOPs.
Hope this is of some help.
Ed
Apr 25, 2009 | Office Equipment & Supplies
Exercise & Fitness Logo
1,728 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
