Hec washing machine spinned but made awful noise, now won't spin. Drum is going round but not releasing water, clothes wet. Door opens fine. Did think I had lost an earring last time I used machine. Any help???
The door switch is defective. It prevents the machine from spinning when the lid is open. Go to repairclinic.com for help and parts. Very easy fix if your handy
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
is the pump free to spin? when the pump operates(when it spins) is the water getting out? something like a sock may have got past the drum into pipe that joins to pump allowing only some water to escape
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
It sounds like you have a problem with your spin/agitate motor or gear assembly. The drain is open it works by water pump and by centrifical motion. Opening thr drain duct shouldn't help anything. It really needs to go in to spin cycle to drain water. As far as it not spinning, you can buy replacemnet parts for the spin/agitate motor and gear drive, or belt drive if it is belt driven..
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
I had the same problem. After releasing the door and removing the wet clothes, I siphoned the water from the drum. Make sure that the water is turned off and the machine is unplugged, Then I opened the large black cap behind the round white cover on the surface. Be prepared to capture about half galon of water. This is the opening to the drain pump. In my case, there were some toys from my kids which had stuck in the turning part of the pump. I removed them and replaced the cap to the pump. Everything seemed to be OK after that.
I hope that this helps. Please be adivsed that I am not a repair person and proceed with caution and use common sense when dealing with electric appliances.
Good Luck
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
