Settings for Weather Data World Clock The clock has 24 world time settings. Function keys are Mode, Set, Select, Advance, Snooze, Al on/off I want to set the time, date and location.
Citizen Weather Data Clock Settings. To set time press and hold for 5sec "set" button Use advance to add days, years, hours seconds. Press SET to hold.
keywords (from display) Ultronic forecast week day humidity temperature trend comfort level - DOWN = toggles F/C temp - UP = toggles alarm - MODE = selects date/time display - hold down MODE to enter "set" mode for data currently displayed - use momentary MODE to choose target item - use UP/DOWN to change item
If it is a desk type clock, hold down the 'mode' button, then the up or down button till the time is correct. To set the alarm, hold down the alarm 'on' button til it flashes the time then the 'up' or 'down' button.
The cd mode is a count down timer. Set it like you would an alarm then press the mode button when finished. Then press the up button to start the timer and then the mode or snooze button to silence.
all you have to do is this: while being in the regular clock mode, just press the DOWN arrow. when you do this, different functions will appear. when you press it once, you will star seeing, instead of the weather in farenheit, the seconds of the watch going by. press it again and ou will see the temperature in celsius. you can keep on pressing it and see that there are 3 modes: -Temperature in farenheit -Seconds of the clock -Temperature in celsius.
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally, press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to blink; press "adv" repeatedly until hour AM or PM is correct. Now press "mode" so that the minutes blink, and use "adv" to get the minutes right; then press "mode" so that the next item begins to blink; use "adv" to advance until it is correct, then press "mode" so that the next item blinks, and so forth until you're all done. Finally, press and release "set".
