Question about Music
Wiring diagram for Les paul special II
I was given a epiphone Les paul special II that has it tone, volume, pickup selector and input jack detatched. I would like a wiring diagarm for reference. Thanks
Posted by markecameron on
Michial Gueffroy
    President:
  • 1,140 Answers
Try here:http://www.seymourduncan.com/support/wiring-diagrams/ or here:http://www.gibson.com/en-us/Support/TechSupport/
Posted on Oct 17, 2009
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Feb 21, 2016 | Epiphone Music
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Where can I get the wiring diagram for an Epiphone Les Paul Special with 2 pickups, and a single volume/tone/selector switch?
Try here:http://www.google.com/imgres?imgurl=http://www.electric-guitar-info.com/images/Epi-wiring-circuit1.jpg&imgrefurl=http://www.electric-guitar-info.com/les-paul-wiring.html&h=348&w=503&sz=48&tbnid=aSO6CWOP8JpBPM:&tbnh=90&tbnw=130&prev=/images%3Fq%3DEpiphone%2BLes%2BPaul%2BSpecial%2Bwiring%2Bdiagram&usg=__tWQm6BV6hWlRkesXsvExeuCGPcI=&sa=X&ei=emZjTP3YCsH38AaV7q2vCQ&ved=0CBgQ9QEwAQ or here:http://www.guitarpartsshop.co.uk/acatalog/electric-and-bass-guitar-circuit-diagrams.html
Aug 11, 2010 | Epiphone Music
Fix the wiring in a epi lp100
http://www.1728.com/guitar.htm
Its basic diagram #2.....but a twin pickup les paul is a twin pickup les paul!
May 06, 2010 | Epiphone Les Paul 100 Electric Guitar
Which knob does what on the epiphone les paul studio? there are 4 knobs and the only one i can figure out is volume.
I believe the top front is volume for the front/neck pickup...the top rear is for the rear/bridge pickup and the other two are tone knobs for the front and rear pickups.
Feb 10, 2010 | Epiphone Les Paul Studio Electric Guitar
Output jack on a Epiphone Les Paul came out and I ned a schematic
google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
Apr 07, 2009 | Epiphone Les Paul Studio Electric Guitar
HELP!
This is exactly how any 2 pickup, 2 volume, 2 tone, three way switch guitar would be wired from the factory. Best of luck!
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Apr 01, 2009 | Epiphone Les Paul 100 Electric Guitar
Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Oct 27, 2008 | Epiphone Music
Music Logo
3,530 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
