Remove the case and confirm that the door latch switch is mechanically intact. Next, disconnect the switch and test it with an ohm meter to see that it is actually working. It should show a short (0.0 ohms) when the door is closed and no reading when the door is open. Those readings could be reversed but there should be two distinctly different readings when testing the switch. If you don't see any differnce between readings when the door is open or closed then replace the switch. This should solve your problem.
