2003 Mitsubishi Outlander Logo
Posted on Oct 16, 2009
Engine stalling after you start going fwd from stop. Such as backing up then going fwd or stopping at a stop light. Mainly after sitting with engine off for a while. Check engine light comes on and then goes out after a couple days. has new plugs. engine code said misfire, but new plugs didnt fix problem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
229
Points
My car is having the same problem. Did you ever figure out the problem?
  • Oscar Agnes Apr 09, 2011
    how about the fuel filter?
Anonymous
Level 1:
New Friend:
  • Posted on Oct 31, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
229
Points
Have you had the fault code rear? Would guess at a coil.
2answers
GMC 2500 Sierra keeps stalling
you check the gas filter when you have a bad one its run to a point the gas cant go throgh its stalls pump stop gas go back and start over again pressure push the dirt again let me no pierre
I got a diagnostic test on my car cause my check engine light is on and it is shaking real bad when driving it and when i stop at a red light it seems like it wants to stall out
P0305 is a # 5 cylinder misfire , do you know what that is ? Check engine light flashing indicates a severe misfire that can damage the catalytic converter . Don't drive this vehicle ,take it immediately to a qualified repair shop or the dealer .
A Ford P0171 is a LEAN code for cylinder bank 1, and P0174 is a LEAN code for cylinder bank 2. These codes commonly occur on many Ford vehicles, and are set when the powertrain control module (PCM) sees the air/fuel mixture is running too lean (too much air, not enough fuel).
Flashing check engine light CarMD
1helpful
Ignition stop firing/engine floods w/ gas
Check for loose connections on your ignition system, mainly around the coil.
Problems with Mercury Sable 04/ stalls, engine light stays on
Could be crank shaft sensor, plus fuel filter tune up plugs and wires, go to auto zone check light it is free.
Engine stalls while sitting at traffic light. Seems to happen after engine wms up
To correct this problem I want you to get a can of intake cleaner (ABOUT $5.00) from any local auto parts store like NAPA or Carquest, do not use carburetor spray, intake cleaner only or u will damage the Teflon coating inside the throttle valve and air bypass valve, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
1helpful
2001 Chrysler Concorde LXI randomly stalling while slowly dow to stop or turn. Will usually crank back. This car will sit and idle for ever, but when you drive it for 10-15 minutes and slow down to stop or...
One suggestion:
Speed sensor failure.
Info:
Some of the classic symptoms, stalling at dead stops. failure to auto lock doors. poor fuel economy. Failure to go to overdrive.
Recommendation:
Go to your local parts store and run the failure codes.
Shop notes:
Your ECU thinks that the engine is running with out moving, During slow down the engine steps down the idle to match ground speed and as a result the engine will not stall. At present it goes directly to idle and stalls due to drag on motor.
Hope this tip helps.
R/
David
3helpful
2answers
Car will start fine but will shut off as soon as I place in gear.
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
2answers
Stalls out when I stop
check the iac i sounds like it is acting up
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
