Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Posted by bflak on
Anonymous
    New Friend:
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Posted on Jul 17, 2011
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Just bought a Pioneer elite PRO101, pioneer elite 25SC receiver and a pioneer elite BDP23 blu ray. I just got a new HD 612 receiver from dishnetwork. I have my HDMI out from the dish receiver to the 25sc....
Check what in the HD 612 receiver what year it was made and the software,frameware version it in the programing.Do the same with the tv might not have compatible version of softwares.
Jun 22, 2010 | Pioneer EliteĀ® PRO-101FD TV
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Jan 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Aug 21, 2008 | Pioneer PRO-99 TV
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
PRO-510HDTV
The intermittencies you mention are common on this
series. The PS - power supply - board needs a
virtually complete resolder op, as the solder used in
that run of units was weak and thin. It will not get
better on its own, any more than needed dental work
will.
Send it to me and I will resolder it and send it back.
I have done so on a number of PS boards in this series,
and am running at 100% success on saving the
510/610/710 series of Pioneer Elites when all they need
is the resoldering op. There is a procedure to follow,
so contact me directly.
www.imageperfection.com
510-278-4247
Mr Bob
Nov 08, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer PRO-510HD Elite
since your tv is 6yrs old it could be that the video circuit has cold solder that needs to be resolder if that does not work then a focus on the video circuit by replacing the component there, it could be an ic or transistors or diode.if you are not a tech get one to look at your set.good luck.for further help email me at [email protected]
Apr 06, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
