Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
This model does not have a built-in Freeview tuner. You will need to attach an external Freeview tuner (or other device such as a PVR containing a tuner) to one of the TV's external inputs.
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Ah...that model has the usual Samsung remote and instruction booklet: both are poorly designed. it's a shame as the TV itself is OK.
To select between digital and analogue channels you use the "source" button to cycle between all sources; there's one button on the TV and another on the remote (from memory it's in the centre of the upper half of the remote, but will be clearly shown in the user booklet).
You must have a digital tuner built in to the tv if you want to scan for Freeview digital channels. If you have digital cable or satellite the decoder box will unscramble the signal and send it to the tv through a scart connection or HDMI cable. Not all tv's have a digital tuner built in but if it is HDTV it can show an increased resolution image if the output from the cable box or dvd player is high definition.
DOES SAMSUNG FLAT SCREEN TV MODEL PSN4231 HAVE BUILT-IN ATSC TUNER??
