Brookstone 538744 Remote Control Logo
Anonymous Posted on Oct 16, 2009
Brookstone big remote 538755
Got codes? mispacked manual in move.
Anonymous
Level 3:
  • Master 403 Answers
  • Posted on Oct 24, 2009
Anonymous
Master
Level 3:
Answers
403
Questions
0
Helped
135537
Points
1103
Here you go. This will work with most all universal remote controls. If you don't have the code do the following: This is mainly for the Brookstone.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Testimonial: "These are indeed the instructions from the Brookstone manual (which I found after I finished unpacking)."
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 16, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2371
Points
5
Thanks a million, exactly what I was looking for. worked like a charm.
Universal brookstone TV remote {big} how too program a vizio tv
Use code search on your Brookstone remote control to find something that works. If a search through all codes stored in the RC fails, try a different one.
1helpful
2answers
Need code Westinghouse TV I have brookstone big digit remote
Hello zmprice, I need a bit more information so I can better assist you, what is the model # and serial # of the TV? Depending on the model # if it is an older model # they normally use Sony codes, whereas if it is a newer Westinghouse TV it probably uses Samsung codes.
I have the big remote from brookstone, but no longer have the code book...how do I locate the correct code for my tv...can I download a code book manual for it?
Click HERE to download the manual.
Incase you need to manually type the web address in it is: http://www.mediafire.com/download.php?9keapl8cx5g3xmg
2helpful
3answers
Need remote codes for the brookstone big remote. RCA is the tv
click the link http://mscustomercare.com scroll to the middle of the page and download instructions for jumbo remote.
I have a big brookstone universal remote but need codes. Where would I find codes for tv vcr dvd on the web at no charge?
Hi I have uploaded a pdf of the manual with all the codes and procedure to program it.
Click HERE to download manual
1helpful
3answers
Have innovage jumbo remote control need codes for panasonic tv
go to Brookstone site and download manual http://www.brookstone.com/bs_assets/files/pdf/product/manual/538744.pdf
4helpful
2answers
Brookstone Remote Codes fore Universal Remote
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/brookstone/supersized-manual.zip&area=other
for brookstone jumbo remote.
Top Brookstone Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
