Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Rheem RTG-74PVN-1 Water heats for abot 2 minutes
Rheem RTG-74PVN-1 Water heats for about 2 minutes then shuts off. Thermostat flashes 76 and C4
Posted by dneuwiller on
Anonymous
    Champion:
  • 248 Answers
Overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Posted on Oct 29, 2009
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 22, 2013 | Rheem EcoSense by 4.2 GPM Tankless Water...
Error code C4 76
Error 76 is communication fault with remote control, or bad PCB board.
Copy following link for Rheem tankless troubleshoot:
Call Rheem, and they will recommend service technician.
800-432-8373
Make sure your unit is serviced yearly to prevent common error codes. Which defeats the robust $100 expected yearly savings from owning a tankless water heater.
Oct 13, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Burner lost comm with the remote code c4 76
Check thermostat connections.......check thermostat leads to the unit.......To check remove thermostat wires(leads) from unit and see if unit comes on and works, unit should work and heat to 120 degrees factory set. If unit does not fire off then problem is the pcb(printed circuit board) and will need to be replaced . When new board arrives it will need to be programed...... hope this helps....
Sep 06, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
http://www.fixya.com/tags/rtg_74pvn
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
FLASHING C4 76
Had a Ploma unit - same as Rheem. Not sure what C4 is...but code 76 is lost comm between the remote control and the burner control module. Unplug unit = take front cover off...their should be a square circuit card assemble in front of you. Top blow capacitors are typically used in todays electronics, and they have an obvious curve if the capacitor is blown. If the caps appear swolen on the top they are blown. STOP! If your unit is less than 5 years old..contact manufacturer for defective power supply. This particular problem is known to the MF...If you have a Poloma/Rheem they send you step by step instructions on how to replace this board yourself...if you're slightly technical you can do this repair yourself.
Oct 26, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Oct 04, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
689 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
