Washing Machines Logo
Question about Hoover Washing Machines
I have a Nextra HNF71683D washing nachine. When i
I have a Nextra HNF71683D washing nachine. When i programme it it says E05. Does anyone know what this means??
Many thanks
Posted by joolsieh on
Anonymous
  • 53 Answers
E05 NTC temperature probe faulty or open circuit.
Posted on Oct 16, 2009
1helpful
How do I change pcb on Hoover Nextra HNL 2126 please ?
make sure u photograph were all the wires go back on with ie ure phone
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
4helpful
HOOVER NEXTRA HNL71663D WASHER DISPLAYING E05 CODE. CAN YOU TELL ME IF THIS IS A SERIOUS FAULT AND NEED TO GET ENGINEER OUT.
I had exactly the same problem. After removing the back panel, I checked the two wires that go into the thermostat, they came away with no problem (not a good thing). Both of the wires were very brittle. I restripped them back and put two new connectors on, the problem was solved. Sounds obvious but make sure you turn the power off!
We are looking for a Programme Selector for a Hoover Nextra HNWL 3136
hi there my best advice is phone gias in rochdale go to gias website for number when you ring tell them you repair washing machine so you get a trade price
Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
3helpful
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Hoover nextra energy saving washing machine
Click on Hoover model number above (below FIXYA) on this website & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line.
Rate me pl if helped.................
Top Hoover Washing Machines Experts
Steve F
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
