I found error in Canon NP6650 copier. LCD show error code P0002. 1) What the meaning? 2) Wich part that error? Thank for assist
Posted by arjal_balad on
  • Brian
    Brian May 11, 2010
    Is there more to the error code? As in more numbers/letters?
Anonymous
  • 168 Answers
The main thermister is bad replace it then clear code in service mode
Posted on Oct 16, 2009
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Could you help me to fix on error of np6650 about e001-e003 turn on again power
E001 - E003 such problems are mainly in the fixing assembly so you need to:-
1. check for the fuser lamp if it is not broken.(if broken replace)
2. the themistor if working properly.(if broken replace)
3. cables leading to the thermistor and the fuser lamp if working well.
5. change the fixing roller if it is finished.
6. reset the machine(in case of IR1600)
Jul 13, 2011 | Canon ImageRunner 1600 Copier
I have a PIXMA MX700, SER# AAXN66483. An error code 6A80 is showing on the LCD. The printer will not respond to any button or command. Need help ASAP. Thank you, Ralph Rodibaugh
Try these are the steps:
1. Turn On mx700
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Is Printer back to normal again?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 03, 2011 | Canon Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Canon ir2116j the problem is after pressing the print butten the lamp carrage not moving right side and display light shut down then again reset what is this problem
wich is the error code that machine shows? i.e. E00002-000
You said that machine says turn off and on, these happens when the error code is present.
And by the way do you mean IR2016J, 2116 do not exsist!
Aug 24, 2010 | Canon iR 2016i Black and White Copier
My canon photocopier IR2016J show error code E007. Advise me on how to resolve it or reset it
my canon photocopier IR2016J show error download and stop averthing no any function. Please advise me on how to resolve it or reset it.
Lachuo
Aug 10, 2010 | Office Equipment & Supplies
Getting error code e000748-4000
E744, means that Language file/BootROM error.
You need to upgrade the DC controller PCB version, wich is done over service support tool. That means that you cant do it on your own, call service.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER C3170U Color Copier
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Jul 10, 2008 | Office Equipment & Supplies
105 people viewed this question
Ekse
Marvin
Marvin
