If you want to check your ip address just visit the http://www.ip-details.com/ & get the ip address
WRITE CLICK ON LAN CONNECTION CHOOSE INTENET PROTOCOL (TCP\IP) AND TYPE192.168.1.1 IN 2ND ROW 255.255.255.0
THEN REPEAT 1ST IN 3RD ROW
THAT'S IT
We need way way more info to help you.
IP address usually comes from the device that provides your internet IE router or modem via a network cable. If you have an IP address and you run windows you can
Access command / dos prompt
Go to Start >> run >> type "CMD"
In the command window type "ipconfig"
This ill list your ip address
if you need more info provide some of the following info:
What OS are you using?
What program is asking for an IP address?
What o you have for a network?
nternet? Home networking? Do you have a cable or DSL modem?
What is the problem that this is causing example no internet?
Do you have more then one computer?
If yo need new hardare check www.RNS-Systems.com
