I own a 1993 John Deere 425 AWS started it, turned it off, and it wont start again. The battery has a full charge, the starter is getting full power. Suggestions???
The service manual says ignition module? The John Deere guy at the service counter said coil pack
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
If engine cranks over and have no spark try a time delay module located under thermostat housing.
