Canon PowerShot S1 IS Digital Camera Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on camera image is blurred and will
When I turn on camera image is blurred...I can see movement but will not focus at all...My brother has the same camera and his recently started doing the same thing! Was never wet or outside- has new batteries....
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Oct 16, 2009
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1194972
Points
12483
  • CameraR
    CameraR Oct 16, 2009
    This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
    Applicable cameras include:
    A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
2answers
Anti-shake is turned on, but photos are still blurry
Too much coffee? Seriously, have you read carefully the user manual that comes with your camera?
Jul 10, 2019 • Cameras
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 • Cameras
My sony dsc t2 vibrates as soon as i switch it on resulting into blurred images.
The auto focus or the lens movement is in error. There can be many reasons for this to happen but if you happend to visit the sea side there is posibilty of sand going into the camera. tap the camera lens with your palm, use a good air pressure into the lens movement. Repeat this for sometime and hope there will be some result before you can open to release the jammed lens drive.
Hope you try. Good day
Aug 17, 2010 • Cameras
1helpful
Focus is blurred yet lense works in /out
check and see the min and max distance for focus in the manual. also slight movement can cause this also.
11helpful
Webcam blurred
Very often this is a problem with the focus. Check if the webcam has a focus ring in front of it and if so, try turning it to sharpen the image.
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Dimage Z3 blurred zoom images
I don't think there's any problem. Simply, a longer zoom means that - without a faster shutter speed - there is an increased probability for camera shake. Additionally, cameras usually struggle with focus in longer zoom. To be sure that there isn't a fault, do this:
1) Place the camera on a tripod or other sturdy surface
2) For additional stability (and to avoid camera shake due to shutter button movement), select the self-timer
3) Focus and take the shot.
If it's still blurry, then yeah, there's a problem
2answers
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
