Question about JBL CREATURE II Computer Speakers
My left JBL Creature II speaker has a green light on, but does not make sound. When I turn up and turn down the volume a clicking sound can be heard from both speakers.
Posted by mwong328 on
  • mwong328 Oct 17, 2009
    I opened my speaker up, but found that the magnet was glued to the casing. Then I read a post saying that the wire going into the actual computer does not need to be plugged in all the way. So I fiddled around with the placement of the wire and both speakers started to work! You will hear a humming sound if isn't plugged in far enough.
Anonymous
I had the same issue and applied ezimme solution from Jan 04, 2009 and it worked perfectly. Thanks ezimme!
Posted on Oct 16, 2009
One of the jbl creature speakers doesn't work
I had the same problem one time and it was a loose connection in the speaker. I will work on any computer but I stay away from anything else. :-) A buddy opened her up and fixed her for me. If it is new, think about taking it back to the store. Thank goodness the prices have come down so much that I am considering getting Bose instead and blasting myself onto the wall behind me. :-)
I used the left hand pad on the control unit to reduce the volume to nothing, and cannot get the level back up again. matthew
  1. Check the power connections on your speakers, make sure that the power LED's on the small speakers are lit.
  2. Make sure the green cable is connected to the computer's speaker port (Usually a green headphone-type jack) and also the the speaker- a similar type jack.
  3. Adjust system volume 2_6_2012_8_52_14_pm.png by clicking, drag volume slider bar up to about 75%, and release.
  4. Turn up speaker's volume using the volume (and bass volume) knob on the main speaker.
  5. Play an audio file. Note that if you are using Windows Media Player, etc. you may need to turn volume up there also.
  6. If you are still having trouble go to start/control panel and select sounds. This will show your installed audio devices. If there are no devices, then please provide the make model, etc. of your computer and I will go from there.
  7. Test the devices in another setting will help identify a hardware problem. For example, test your speakers with an MP3 player, or your computer's CD-ROM usually has a headphone jack; test the audio on your PC with a set of headphones, or another set of speakers. If either of these fail it may indicate a hardware problem. Feel free to post back any additional information and I will try to provide further help. Please include your make, model, and version of windows so I can provide specific info for your PC.
I found the following info on your speakers, which you may also find helpful:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Thanks for purchasing my services, and please remember to leave feedback once your problem is resolved.
1helpful
4answers
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
3helpful
There is no sound coming out of one of my speakers (the one with volume control). The green light underneath comes on and the volume control itself works but no sound comes out of it.
make sure the balance is set properly in the volume controls tab located by right clicking on the speaker icon in the lower right hand side in the startup tool bar
3helpful
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
2answers
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
1helpful
JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
JBL CREATURE II Computer Speakers Logo
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
