Question about Kodak EASYSHARE G610 Thermal Printer
The printer will not pull photo paper through and print the pictures.
Posted by brianmichaud on
Anonymous
    New Friend:
  • 3 Answers
Had same prob with G600, all i had to do to get it working again was to clean the rollers with a damp cloth to get it working again.
Posted on Dec 14, 2009
I have Epson stylus TX121 printer but whenever i m using to print out photo, photo comes in orange and red color, pls help me ....
Hi
When switching from printing on standard paper to photo paper, you need the change the paper and picture quality settings in Printing Preferences.
Start > (Control Panel) Printer(s) > right click on the Epson TX121 printer icon > Printing Preferences > Main > tick Photo or Best Photo > under Paper Options/Type select the closest match to the type of Photo Paper you are using (see photo paper packet for guidance) > Apply > OK.
Use the same procedure to switch back to standard paper settings to print on normal paper again.
I hope this helps
Aug 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
What paper feeder does the 4x6 photo paper go into to print a photo
Pull the paper out of the feeder tray. You will see small marks and a sliding plastic lever. use the picture to determine whether the photo paper is loaded face down or up and then slide the lever over until it hugs the photo paper snugly.
Mar 21, 2011 | Canon PIXMA iP3600 Photo Printer
I am trying to print 4*6 pictures on c6280 from my Apple PC. No matter what settings I ask for it pulls the paper from the 8.5*11. How do I set it to print 4*6 pictures?
Hi, It senses the size of paper you put in the tray, that is if you have placed A4 paper, that is what it will use. Options are, use 6*4 paper or print 2 up on A4. To use 6*4 paper raise the paper tray and then pull out the photo tray. If you can't follow this, go to http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Aug 25, 2009 | HP Photosmart C6280 Printer
Pictures printed from computer are pale and faded
Are you using photo paper to print your pictures? If you print your photos on regular paper the ink on the photos can bleed or run together in the paper fibers. Try using paper made to print photos and see if that helps
Dec 05, 2008 | Office Equipment & Supplies
My printer wont print on photo paper.
Is it worked in past? Have you contact the HP for this problem? Since most of All-in-one printer do not possess better print facility, so it is difficult to use this one for photo print..
Photo paper is thick and may be motor not taking complete load of it. Check out with the roller moving firmly.
Oct 27, 2008 | HP DeskJet F380 All-In-One Printer
I need your help please.
Make sure you are using the paper that come under the specifications of the printer (102 x 153 mm (4 x 6 inches) for a Photo Paper). Though you are using the correct paper and you are getting the same message, then just set the paper type as "Plain" and try to print from the photo paper. It works in most of the cases
gud luck
Oct 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing digital photo on 8x11
Right click on the photo to be printed and select edit. When the picture is displayed pull down file and select 'page set up'. Set to fit 1 to 1 pages. Leave the margins and center were they're at. Pull down file and select 'print preview'. If this fits covers most of the page , type c (this closes this window and returns you to the previous one).and pull down file and select 'print'. If not again type c, select file and 'page set up' again and select land scape. If this is better, print this
May 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
Kodak EASYSHARE G610 Thermal Printer Logo
536 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
