HP Pavilion dv6000z Notebook Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp pavillion tx2000 all lights are on - hard
Hp pavillion tx2500 all lights are on - hard drive light seems to be working-
mouse pointer is on screen & working
screen is dark
Electronics Repair
Level 2:
Sergeant:
Champion:
  • Expert 452 Answers
  • Posted on Mar 09, 2010
Electronics Repair
Expert
Level 2:
Sergeant:
Champion:
Answers
452
Questions
Helped
71122
Points
975
That's a very common issue with that model, You will have to reflow the GPU with a heatgun. You can find more info from http://www.msbin.com if needed.
2answers
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Hp pavillion tx2000 entertainment notebook pc. initial o/s vista home premium. Problem with cursor drags automatically. whole system scan with kaspersky antivirus. problem not solved. o/s changed to...
You meant the built in mouse pad fails.
why not use wired USB mouse, now, and end the pain ,
then with a working mouse , get the HP driver from HP
and install it from HP. for W7. (luck)
at HP, fixyah is not HP, not at all..
that will work, if not driver issue, then buy a new pad. oops none are sold new.
after 10 years. so that leaves what, used pads sold on ebay..'
HP dot com. your support page. (seems to be collapsing from age)10years old it does. by hp rules.
even the tx2500 series is 10 years old now.
https://support.hp.com/us-en/product/HP-Pavilion-tx2000-Entertainment-Notebook-PC-series/3650975
does your service tag show tx2000 , that is series
not telling the service tag number gets you wrong facts.
wrong drivers, so next time show the full model
try the support assistant there.?
here are the full list of tx2000 series PC
see ,its not just one PC, we need the full model p/n to answer
with any accuracy at all.
http://partsurfer.hp.com/WSearch.aspx?Wchar=Y&searchText=tx2000#
there is no guarantee at all any w7 driver exist. for your mouse pad but many times the Vista version will work
you lost that now, i you dont have the install disks from HP.
or the pad is simply bad.
we have tools here to scan your pad chips to see the makers
name and then get driver from them direct. after HP drops support.
2answers
HP tx2000 - black screen.
Hi
The problem you are experiencing is related to the screen of your Hp.
All you need to do is to is to get to a computer store and get your screen replaced.
You can not fix a damaged screen.
GOOD LUCK
I have to turn it on and off for several times just for it to start wroking
If you get just a black screen - all lights on except hard drive light and fan seems to be working, then you are probably experiencing the same GPU (video chip) issues as others. Here is a good read - http://h30434.www3.hp.com/t5/TX-series-notebooks/Familiar-Story-tx2000-lights-and-fan-on-but-black-screen-at-boot/td-p/87361
...and here is the service manual if interested in trying the permanent fix yourself.
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Regard!
I have got the same problem to.
Are you able to enter the bios?
Try swapping / reseatting the memory.
Booting without the battery / hard drive / dvd drive as well.
Does the laptop feel hot or is it making any weird noises?
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
