...My wife and I Cracked a Crock Pot- had to run to a few " Thrift Stores" to get a Cheap Backup. Remember to take along the BASE of the crock pot with you-to check for Correct FIT.
contact manfacturer to see if it is under any kind of warrany of if it was flawed if no luck may be cheaper to replace.They are always on sale somewhere we have 3 of them all different siZes
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
If might not be the thermal pot, it is possible it is the machine itself. If you have a candy or meat thermometer, place it in the pot as soon as the coffee has completed brewing. The temperature should be at 175-185 degrees. If it isn't, then the machine needs replaced. If the temperature is correct, then please call customer service with the model and date code to get the thermal carafe replaced. If the temp isn't correct, and it is 3 years old or less, the machine will be replaced for no cost. If it is over 3 years old, it can be replaced at a reduced price.
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
My 1994 XJS is the same way. Many suggest it is the crummy metal inside the door handle (Pot Metal) and/or the plastic connectors. I just got mine the other day, but what can I say, I am 13 years old. My dad and I are going to tear it apart over the next few months.
