Koss dvd player kd305a plays black and white.
Kkoss dvd player kd305a plays black and white for any and all DVDs. There is sound and there is a picture, but the picture is black and whtie, no color. My TV is a Samsung PN42A400C2D...maybe I have the cables wrong? Not sure how it should be hooked? Ideas?
Posted by alpencroft on
Nanny
    Genius:
  • Televison & ... Master
  • 2,351 Answers
Generally, the main causes of the problem are included in the following aspects.
1. The incorrect TV and DVD broadcast formats.
2. Incorrect cabling.
3. The backlight of the TV screen is abnormal or broken.
4. Objective factors, like whether and connection signal.
You can check more here:
Why is My DVD Playing in Black and White
Posted on May 25, 2020
Jamie Andrew Knights
  • 244 Answers
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Posted on Oct 16, 2009
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
How to play ipod on koss progressive scan
Take a look at the inputs on the DVD player. If it has an AUX input (looks like a headphone jack) you may be able to connect with a male to male 3.5mm headphone jack. Otherwise you could use a converter that goes from headphone jack to RCA (Red, White, Yellow)
Jul 30, 2012 | Koss KD305A DVD/CD/MP3 Player Progressive...
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Loss my remote for my dvd player
Hey
I was checking around for you and you can get an orignal replacement remote for your unit at www.remotes.com
Please take a second out to rate my answer!
THANK YOU!
Jan 16, 2009 | Koss KS4110 DVD Player
KS4190 does not play all DVD's.
if the dvds are in the correct code for your player and they still can not be read try cleaning them with a little bit of white spirit then drying them off gently with a dry cotton cloth. You can also try using a cd lense cleaner for the dvd itself to clean the lease to see if this makes a difference. Other to that it sounds like the dvds are either in the wrong region or maybe are copied versions which some dvd players will not read.
I hope this helps.
Dec 05, 2008 | Koss KD365 DVD Player
Koss dvd kd305a. when i play a dvd i get sound but no video.
Hi, I'm not sure if this will fix your problem, but I had the same problem with a Koss KS3102 model. I had switched from NTSC to PAL from the menu screen by mistake and was no longer able to view the menu. I went to justanswer.com and the problem is now fixed. I had to pay, but it was well worth it, so if you can tell me more about your problem I will try to assist you if it is the same as mines. [email protected]
Sep 03, 2008 | Koss Televison & Video
Open Questions:
Televison & Video Logo
359 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
