1998 Volkswagen Beetle Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to Disconnect Windshield Wiper Motor in 1971 Beetle?
When I turned the wipers on the other day, they stopped suddenly, the car refuses to start again, and a loud buzzer sounds from behind the dash whenever the car is turned on.
My theory (though I know nothing about cars) is the wipers caused a short somewhere, and that I can just disconnect the wiper's motor to stop the shortage from happening. 1) Will this work, and 2) How do I do it?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 278 Answers
  • Posted on Oct 15, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
278
Questions
0
Helped
109195
Points
741
Some car require that the wipers go to full rest befors the electric is turned off. Sounds like they are stuck and the car does not like it. Find the fuse to the wipers and pull. But the motor seems to be bad and gave up.
1helpful
2005 crown vic. p71v 1st the fluid stopped and the wipers would'nt shut off, now 1 day later no fluid still and the wipers stop working completely, please help me
Principles of Operation
The windshield wiper motor receive inputs from the following:
  • multifunction switch
  • lighting control module (LCM)
  • ignition switch
  • battery junction box (BJB)
  • central junction box (CJB)
The following components are integrated into the windshield wiper motor:
  • windshield wiper motor module
  • high/low speed relay
  • run/park sensor (Hall effect)
  • washer pump relay
High Speed Windshield Wipers
High speed is activated when the multifunction switch supplies ground to the windshield wiper motor module inputs. The windshield wiper motor module then supplies ground to the run/park sensor and high/low relay coil, activating the relay with voltage supplied from the ignition switch (RUN/ACC) through the central junction box (CJB). When the windshield wiper motor module receives voltage from the run/park sensor, it removes ground from the run/park sensor, deactivating it. The windshield wiper motor continues to operate from voltage connected through the run/park sensor until the Hall effect senses the magnet in the motor. When the Hall effect senses the magnet in motor the windshield wiper motor returns to the park position, the internal run/park sensor grounds the windshield wiper motor module input and the windshield wiper motor module removes ground from the windshield wiper high/low relay coil, deactivating the high/low relay and windshield wiper motor. The windshield wiper motor module continues to cycle the windshield wipers until the inputs from the multifunction switch are changed from the high speed position.
Low Speed Windshield Wipers
Low speed is activated when the multifunction switch supplies a specific ground to the speed inputs of the windshield wiper motor module. The windshield wiper motor module then supplies ground to only the windshield wiper run/park relay coil, activating it. When the windshield wiper run/park relay is activated, the deactivated windshield high/low relay connects voltage to the windshield wiper motor low input activating the wiper motor. The windshield wiper motor module continues to operate the windshield wiper motor in the same manner as in high speed, but in low speed with the wiper motor connected to the low speed input.
Intermittent Speed Windshield Wipers
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper run/park relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated, supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect sensors senses the wiper motors magnet, which turns off the run/park sensor output to the windshield wiper run/park software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
Washer System
The windshield washer is activated by the internal wiper motor module when it receives a ground from the multifunction switch between the washer input. Dependent on the correct ground, the internal wiper motor modules activates the windshield washer relay (internal) by grounding the respective relay coil. When the relay is activated, it connects voltage to the washer pump while the washer level switch provides ground to the washer pump.
Default Mode
The windshield wiper motor defaults to this mode when the run/park sensor does not sense the hall effect magnet inside wiper motor. This can be caused by obstruction of the windshield wipers or a binding linkage. The windshield wiper motor will continue to operate in a high/low speed condition for a period of 60 seconds.
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The wipers are inoperative
  • Multifunction switch
  • Circuitry
  • Ignition switch
  • Windshield wiper motor
  • Go To Pinpoint Test A .
Do you know how to test automotive electrical circuits using a factory diagnostic test procedure flow chart ?
PINPOINT TEST A: THE WIPERS ARE INOPERATIVE Test Step Result / Action to Take A1 CHECK CIRCUITS 65 (DG) AND 2025 (RD/YE) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Windshield Wiper Motor C125.
  • Key in ON position.
  • Measure the voltage between windshield wiper C125 pin 5, circuit 2025 (RD/YE), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 65 (DG), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to A2 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A2 CHECK CIRCUITS 57 (BK) AND 676 (PK/OG) FOR OPENS
  • Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 676 (PK/OG), harness side and ground.
  • Are the resistances less than 5 ohms?
Yes
GO to A3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A3 CHECK THE MULTIFUNCTION SWITCH
  • Disconnect: Multifunction Switch C202b.
  • Carry out the multifunction switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Does the multifunction switch pass the component test?
Yes
GO to A4 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . A4 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between C202b pin 5, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to A5 .
No
REPAIR the circuit. TEST the system for normal operation. A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between the multifunction switch C202b harness side and the windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 pin 6, circuit 56 (DB/OG) pin 10, circuit 56 (DB/OG) pin 3, circuit 58 (WH) pin 11, circuit 58 (WH) pin 1, circuit 61 (YE/RD) pin 1, circuit 61 (YE/RD) pin 4, circuit 63 (RD) pin 9, circuit 63 (RD)
Yes
GO to A6 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Disconnect all wiper motor connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all wiper motor connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
GO to A7 .
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. TEST the system for normal operation. A7 CHECK THE WINDSHIELD WIPER MOTOR
  • Carry out the windshield wiper motor component test as outlined in this section.
  • Does the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. The concern may have been caused by binding or incorrect pivot arm adjustment. REFER to Windshield Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
1helpful
What could be my problem for my windshield wipers to suddenly start and stop working?
It could be the screws are loose (at the bottom end of the wipers)
There may be a rubber cap you will need to access the screws. (Also worth checking if the wiper motor is working when wipers are not)
Other possibility, the wiper motor fuse is loose with intermittent connection - locate the fuse box and take out all fuses, inspect them for damage/burn marks and insert them firmly back.
Hope this helps
2answers
I have a 2007 mustang an the wipers wont turn off I had 2 pull the fuse to turn them off can u help me
The windshield wiper motor is a smart wiper motor with an integrated electronics module. The internal components of the motor are the high/low relay, washer pump relay, and the run/park relay and associated electronics.
The windshield wiper motor receives its inputs from the windshield wiper/washer switch. These signals are ground reference signals. When the switch is placed in different positions, various input signals are selected and sent through circuits to the motor. The windshield wiper motor module identifies these selected input signals and activates the motor to the selected function.!
Your probably going to need a new wiper motor ! ! ! But you should always test before replacing parts !
Visual Inspection Chart Mechanical Electrical
  • Windshield washer pump hoses
  • Windshield wiper mounting arm and pivot shaft
  • Bussed electrical center (BEC) fuse 10 (30A)
  • Smart junction box (SJB) fuse 3 (10A)
  • Circuitry
  • Windshield wiper/washer switch
  • The wipers stay on continuously
  • Circuitry
  • Go To Pinpoint Test C .
PINPOINT TEST C: THE WIPERS STAY ON CONTINUOUSLY s6b~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use the correct probe adaptor(s) when making measurements. Failure to use the correct probe adaptor(s) may damage the connector.
Test Step Result / Action to Take C1 CHECK THE WINDSHIELD WIPER/WASHER SWITCH
  • Disconnect: Windshield Wiper/Washer Switch C2137.
  • Carry out the windshield wiper/washer switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Does the windshield wiper/washer switch pass the component test?
Yes
GO to C2 .
No
INSTALL a new windshield wiper/washer switch. REFER to Wiper/Washer Switch in this section. C2 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR A SHORT TO GROUND
  • Measure the resistance between the windshield wiper motor C125, harness side and ground as follows:
    Windshield Wiper Motor C125 Pin Circuit C125-10 56 (DB/OG) C125-11 58 (WH) C125-1 63 (RD) C125-9 61 (YE/RD)
  • Are the resistances greater than 10,000 ohms?
Yes
GO to C3 .
No
REPAIR the circuit(s). TEST the system for normal operation. C3 CHECK FOR CORRECT WINDSHIELD WIPER MOTOR OPERATION
  • Disconnect all the windshield wiper motor connectors.
  • Check for:
    • corrosion.
    • pushed-out pins.
  • Connect all the windshield wiper motor connectors and make sure they seat correctly.
Yes
INSTALL a new windshield wiper motor. REFER to Wiper Motor in this section. TEST the system for normal operation.
No
You
3answers
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Wipers stop in the middle of my wishield,will not park properly
Sorry , no adjustment .
Wiper/Washer System Components
The Wiper / Washer System consists of the following components:
• Windshield wiper / washer switch
• Windshield wiper system module / motor
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR 25A fuse
Wiper / Washer System Operation
The windshield wiper motor module is part of the windshield wiper motor cover and controls the wiper motor operation. The windshield wiper motor is a 2 speed motor. Windshield wiper DELAY operation is a low speed wiper motor function with a variable delay interval between the wipe cycles. The DELAY interval is controlled through a series of resistors within the wiper / washer switch.
Park Position Operation
When the windshield wiper / washer switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the wiper motor module will continue to operate the wiper motor until the wipers reach the park position. If the ignition is turned off while the wipers are in mid-cycle, the wipers will stop immediately where they are. The wipers will park the next time the ignition is cycled to the ON position.
Do you know how to do diagnostic's ?
Wipers Blades Do Not Park
Step
Action
Yes
No
Schematic Reference: Wiper/Washer Schematics
Connector End View Reference: Wiper/Washer Connector End Views
DEFINITION: This table diagnoses the wipers operate normally but will not return to the park position when the wiper operation is cancelled.
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Turn ON the ignition, with the engine OFF.
Move the wiper switch to the LO position.
Move the wiper switch to the OFF position.
Do the front wipers advance to the park position?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Turn the ignition switch to the RUN position.
Turn the wiper switch to OFF.
Disconnect the wiper/washer switch connector.
Do the wipers park?
YES - Go to Step 7
NO - Go to Step 4
At the wiper/washer switch connector, measure the voltage of the windshield wiper switch signal 2 circuit.
Does the voltage measure greater than 1.0 volts?
YES - Go to Step 5
NO - Go to Step 8
5
Reconnect the wiper/washer switch connector.
Disconnect the wiper motor connector.
Measure the voltage of the windshield wiper switch signal 2 circuit.
YES - Go to Step 6
NO - Go to Step 8
6
Repair a short to battery positive voltage in the windshield wiper switch signal 2 circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Did you find and correct the condition?
NO - Go to Step 9
7
Replace the wiper/washer switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column - Tilt.
YES - Did you complete the replacement?
NO - Go to Step 9
8
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
NO - Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Wipers don't work on intermittent. They run but stop in they middle of the windshield and don't go to the bottom like normal, Then they run again and stop some other spot. When put on continuous they...
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper RUN/PARK relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect senses magnet to turn off RUN/PARK sense the output to the windshield wiper RUN/PARK software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
  • The intermittent windshield wiper speed does not operate correctly
  • Multifunction switch.
  • Circuitry.
  • Windshield wiper motor.
  • Go To Pinpoint Test D .
Pinpoint Test D: The Intermittent Windshield Wiper Speed Does Not Operate Correctly
Normal Operation During normal operation, the windshield wiper motor receives voltage at all times through battery junction box (BJB) fuse 1 (30A), circuit 65 (DG). The windshield wiper motor also receives power with the ignition switch in RUN or ACC positions through central junction box (CJB) fuse 33 (15A), circuit 1002 (BK/PK). Ground is provided to the windshield wiper motor through circuit 676 (PK/OG) and circuit 57 (BK). The run/park and high/low relays are contained in the wiper motor electronics. Mode of operation is dependant on the signal(s) received from the multifunction switch.
    Possible Causes
  • Open in circuit 57 (BK), 56 (DB/OG), 61 (YE/RD) or 63 (RD)
PINPOINT TEST D: THE INTERMITTENT WINDSHIELD WIPER SPEED DOES NOT OPERATE CORRECTLY Test Step Result / Action to Take D1 CHECK THE MULTIFUNCTION SWITCH
  • Did the multifunction switch pass the component test?
Yes
GO to D2 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . TEST the system for normal operation. D2 CHECK CIRCUIT 57 (BK) FOR OPEN
  • Measure the resistance between multifunction switch C202b-6, circuit 57 (BK), harness side and ground.
Yes
GO to D3 .
No
REPAIR the circuit. TEST the system for normal operation. D3 CHECK CIRCUITS 56 (DB/OG), 61 (YE/RD) AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between multifunction switch C202b harness side and windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 Pin 2, circuit 56 (DB/OG) Pin 10, circuit 56 (DB/OG) Pin 4, circuit 61 (YE/RD) Pin 1, circuit 61 (YE/RD) Pin 1, circuit 63 (RD) Pin 9, circuit 63 (RD) Pin 3, circuit 58 (WH) Pin 11, circuit 58 (WH)
Yes
GO to D4 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. D4 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Check for:
    • corrosion.
    • pushed-out pins.
Yes
GO to D5 .
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. D5 CHECK THE WINDSHIELD WIPER MOTOR
  • Did the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. Concern may have been caused by incorrect binding pivot arm adjustment. REFER to Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
I have a 1998 golf mk4 1.9 tdi. the electrics seem to work when they wont to! and are doing funny things! for example my headlights stop working! the work the next day ? when i start my car the back...
Windshield Wiper Motor could be causing starting and stopping where it feels like: REMOVAL & INSTALLATION Fig. 1: Remove the water shield fasteners 91226p14.jpg
Fig. 2: Using a suitable pry tool, lift up the base of the clip while turning the head 91226p13.jpg
Fig. 3: View of water shield retaining clip 91226p15.jpg
Fig. 4: Removal of the water shield weather stripping 91226p16.jpg
Fig. 5: Pull away the water shield 91226p45.jpg
Fig. 6: Remove any dirt and debris from the under the water shield at this time 91226p43.jpg
Fig. 7: Detach the wiper motor wiring harness 91226p48.jpg
Fig. 8: Removing the wiper motor and linkage assembly 91226p39.jpg
Fig. 9: Remove the screws from the wiper motor assembly 91226p40.jpg
When removing the wiper motor, leave the mounting frame in place. If possible, do not remove the wiper drive crank from the motor shaft.
  1. Disconnect the negative battery cable and remove the water shield at the base of the windshield.
  2. Disconnect the relay rods from the wiper motor.
  3. Note the position of the crank arm on the shaft. When the motor is in the parked position, the arm should be about 4 degrees up from horizontal.
  4. Disconnect the wiring and remove the bolts to remove the motor from the frame. To install:
  5. Temporarily connect the wiring and run the motor. When the wiper switch is turned OFF, the motor will stop in the parked position.
  6. Install the motor and connect the linkage.
  7. Run the motor again and make sure the arms and blades are properly positioned when the motor stops.
After looking at the schematics, I couldn't determine which subsystem may be causing your problem with the headlights. There is a daytime running lamps subsystem, but I am not sure if that's causing the problem. There are fuses involved but not sure if that's the problem.
There's a solid state headlight switch, but I'm not sure if that's a problem.
On the headlight issue, if it doesn't come back, just consider it a bug or glitch.
Have you had a battery changed on it recently?
My windshield wippers suddenly stopped working after my neighbor poured water when the windshield froze due to cold water
1. Start the vehicle and turn ON the Wipers. Open the Hood. Go to the base of the left wiper and flip up the hinged cover. Do you hear the Wiper Motor running? Do you see the nut and the wiper bolt moving, but not the wiper arm? If so then this nut needs to be tightened down and your Fixed!
IF this does not fix the problem:
2. Check the Fuse for the Wipers. It is located in the Fuse Panel located on the lower left side of the dash. Remove the cover to gain access. I believe it should be Fuse #11 20-amp. But consult your owners Manual to be sure.
3. To rule out the Wiper Motor:
a. Turn the Ignition to the On (not start) position.
b. Turn the Wiper Switch to the ON position.
c. Use a jumper wire between the motor and a good ground. If the motor works then it is a bad Ground. Remove the ground retaining nut, clean both the Gorund connection and the post., replace, and recheck operation.
4. Disconnect the electrical connection to the Wiper Motor and again with the Engine On and Wiper Switch - ON: Check for voltage. If no voltage then there is problem with the Wiper Switch of the Wiring.
Let me know if this helped, or if you have addtional information or questions. Feel free to contact me at FixYa.com!
1helpful
Need to get a programmer dont know where its at
  • Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
  • Damaged turn signal and windshield wiper switch .
  • Damaged windshield wiper motor .
  • Damaged windshield wiper control module.
Pin Number Circuit Circuit Function 1 57 (BK) Wiper Motor Ground (Park) 2 28 (BK/PK) Wiper Module to Wiper Motor (Park Switch) 3 65 (DG) Wiper Motor Power (Park Feed) 4 61 (Y/R) Wiper Motor Common (RUN) 5 56 (DB/O) Wiper Motor LO 6 58 (W) Wiper Motor HI
Windshield Wiper System The windshield wiper system consists of :
  • Windshield wiper motor (17508) (F-type).
  • Washer system.
  • Windshield wiper control module.
  • Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
  • Located at the instrument panel fuse panel.
The windshield wiper motor is:
  • Attached to the cowl top extension (021A36) .
  • Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
  • Rotary wiper switch.
  • Push type washer actuator.
OFF/Low/High Speed
  • Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
  • The windshield wiper motor has a brush rigging that permits selection of low or high speed.
  • When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
  • When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
  • In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
  • When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
  • When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
  • The wipers make single wipes separated by pauses.
  • The rotary switch is on the end of turn signal and windshield wiper switch .
  • The length of the pause can be set from approximately 1 to 17 seconds.
  • Length of pause decreases as the rotary switch is rotated away from off.
  • Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
  • It is normal to hear a slight click at the beginning of each on/pause cycle. NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
10helpful
Wiper motor replacement
SECTION 501-16: Wipers and Washers 1999 Town Car Workshop Manual REMOVAL AND INSTALLATION Mounting Arm and Pivot Shaft Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the windshield wiper pivot arms (17527).
    1. Remove the nuts (one each side).
    1. Remove the windshield wiper pivot arms.
  1. Remove the LH and RH cowl top vent panels.
    1. Remove the hood weatherstrip.
    1. Remove the screws.
    1. Remove the retaining clips.
      • Disconnect the LH and RH washer hoses.
  1. Position the windshield wiper mounting arm and pivot shaft (17566) assembly aside.
    1. Remove the nuts.
    1. Remove the bolt.
    1. Position the windshield wiper mounting arm and pivot shaft assembly aside.
  1. Remove the windshield wiper mounting arm and pivot shaft assembly.
Motor —Windshield Wiper Removal
  1. Remove the windshield wiper mounting arm and pivot shaft (17566) assembly; refer to Mounting Arm and Pivot Shaft .
  1. Remove the windshield wiper motor (17508).
    1. Remove the output shaft bolt.
    1. Remove the bolts.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
