Sunfire True Sub Signature Subwoofer Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need an organization who can service my Sunfire True Subwoofer - it is 13 years old and has simply stopped working Gary [email protected] 704-474-3988
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Oct 23, 2009
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
120947
Points
1083
Big red
if its that old then you should keep it look for spare parts from other subs just make sure it is worth it
1helpful
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
1helpful
It seems my Sunfire True Sub sig needs repair, but how to do it?
Capacitors either fail spectacularly or in a very subtle way. Every once in a while, they'll explode, in which case it's very easy to spot the one that needs to be replaced, but generally they fail internally, with no visible problems.
(very old units used a wet electrolyte, and the capacitors simply dried out inside)
If you are able to determine which cap is bad, you will definitely need soldering skills to replace it - no way around that.
Soldering isn't difficult to learn, but I can't help you over the internet. :) If there's a craigslist in your area, you might try posting to the "Wanted" section to see if someone can teach you how.
Best of luck to y
2helpful
3answers
My sunfire subwoofer starts making humm noise after a couple minutes while listening music,,, I have to disconnect and connect back, is something that involves equipmenrt adjustment?....thanks
Try plugging the unit into a clean power supply without anything else on it. I had this problem for years and eventually resolved it by moving the system to a different room that has three power circuits - the sub is now on it's own circuit and I don't have the problem anymore.
Has light but no sound
The first thing to always check first is the fuse. This will probably involve some disassembly but it is alwayst the cheapest fix and a constant issue.
Top Sunfire Audio Players & Recorders Experts
 Grubhead
Grubhead
nexrad_chris
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
