Question about RTO 50cc Moped Scooter
2007 50cc moped.wire with the fuse getting hot
2007 50cc moped.wire from tyhe battery getting hot and battery sparks
Posted by stephenkessi on
Anonymous
    Problem Solver:
  • 12 Answers
Check the whole system over an see if evory thing is fastened securley,make shure that no two wires are toucing!
Posted on Oct 15, 2009
On my honda 50 cc moped nthing happens when i press starter button nothing hapens trevor
The first thing to do is get a multimeter and check your battery. I assume it's 12V so you'll need a minimum of 12.6V. Then put your negative lead on battery negative and positive lead on the hot wire to the starter. If you have battery voltage when you hit the button move your negative lead to the starter ground and check again. If you have battery voltage then your starter is bad. The maximum voltage loss acceptable is .5V from battery voltage. If you don't have battery voltage after the first test possible fuse wire or switch, if not after the second test bad ground.
Jan 31, 2017 | Honda Motorcycles
I have no spark on my 1969 Honda 90 passport moped any help??
I believe that this moped has a magnito and it is probably not functioning
Jun 09, 2014 | Cars & Trucks
Electronic ignition not starting engine
check your battery ignition lights should glow fuel gauge should quickly rise to level of fuel in tank. If battery in good order electric start should turn over quickly if not recharge or replace battery.
Check spark plug clean remove plug and clean plug with wire brush
reset plug gap if you dont have feeler gauge use credit card to set.
Check plug spark by laying onto exhaust or other earth and turning motor over. If you have a good spark then refit plug and attempt to restart.
Look on u tube lots of films on restarting dead mopeds.
Sep 26, 2013 | 2005 Cpi Oliver 50
Lost key to moped, how to rewire
The best thing to do is to visit your local Kymco dealer with proof of ownership and the vehicle identification number and have them get you another key. Hot wiring the ignition could be a unsafe thing to do and it could damage other electrical components.
Oct 08, 2012 | Kymco Motorcycles
El diagram til pgo comet
my moped starts but does not running. period 6 mounths was in garage and did not use then, battery and spark plug and etc are ok, I think for cold weather and long time that was not in use . how to solv this problem+
Jan 24, 2012 | 2008 PGO Comet 50
My moped does not creat a spark with the spark plugs. how do i get it to spark?
Make shure the wires on the coil are not reversed
Also the end of the spark plue wire are prone to being loose go to your local auto parts store and get a new spark plug end for it when you install it rememer to cut a quarter inch off to get full access of the center of the spark plug wire then put the new end on it .it has happen to me with the same problem.
Try a differnt spark plug
One Other Though put a meter on the witers comming from the stator make shure you are getting 13.5 voats frome it (If you Have A Battery)
Best Reguards
Larry
Nov 07, 2009 | RTO 50cc Moped Scooter
RTO 50cc Moped Scooter Logo
953 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
rostit
ray gallant
Are you a RTO Toy Expert? Answer questions, earn points and help others
