Pressing the Voice Mail button only checks messages on the FIRST LINE. The Message Waiting Indicator (MWI) lights of all lines. Check the icon next to your other line buttons. One should be an envelope. Press that Line Button, THEN press the Voice Mail button.
Yes, the was bothering me for some time. I think the indicator is a little green light that blinks in the extreme upper left hand portion of the phone...not on screen, above it....but the blinking light may indicate a missed call or a voice mail is present.
Try this. Go into your phone icon, press and hold '1' and listen to any open messages. Delete each. Next go into your Call Log and delete all call history. Now exit.There should be no green light flashing in the upper left hand corner of phone. You have just cleared everything.
Next call your phone but hang up before leaving a message. Note the blinking green light in the upper left hand corner apparently indicating you missed a call. Go into your Call Log. It will say one missed call. Exit the call log and note that the blinking light is now off. You have acknowleged the call in the call log so the light goes off when you exit.
Call the phone again. This time leave a message. Note the blinking light again. Go into your call log again. Note the missed call. It would be nice if there was an icon or something HERE that indicates if this call left a voice message....but there does not appear to be. Exit again. This time note that the light continues to blink even though you entered the call log and acknowleged the call. I believe it continues to blink because you have a voice message. Exit.
Go into the call log again. Delete the missed call from the call hsitory. Exit. The light still blinks, I believe still indicating a voice message.
Go to your phone icone. Press '1' to check messages, delete the message and exit. The blinking is now gone.
So it appears a blinking green light indicates a missed call. If it still blinks after exiting the call log, you have a voice message.
If someone figures something else out let me know because this stinks!
Q: What should I do if I my Message Waiting Indicator, stutter dial tone or light on my phone, is on but I have no new voice messages? A: Make sure to check all message types when reviewing your messages (i.e. voice, email and fax). Q: What should I do if my Message Waiting Indicator (MWI), stutter dial tone or light, is stuck on? A: Power cycle (turn off/on) the Phone or Customer Premise Equipment (CPE).
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
This can usually be fixed by calling the phone number that the voice mail indicator light is flashing on from a different phone number. Leave a voice mail message and then go into the voice mail and delete the message that you just left. The indicator light should then go out.
I have a Uniden 5.8 GHz and the message indicator light will not stop flashing. The phone screen says I have a voice mail but I don't. Does anyone know to fix it?
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
A beep sounds and the message alert tone is reset.
I resolved the problem but I'm not 100% sure of how I did it. If it happens again I'll try it again. I left the answering machine OFF so the Voice Mail would take any messages. A friend phoned and left a message in the VOICE MAIL, I knew this because of the broken dial tone when I went to make a call. When I erased his message the 'New Voice Message' displayed on the handset disappeared. I figure a previous caller hung up just after the voice mail picked up. It was not long enough so it did not register in the voice mail but somehow registered on the GE phone. Since there wasn't anything registered in the VOICE MAIL to erase the message was 'stuck' on the handset display. As soon as there was a message registered in the VOICE MAIL that could be erased it also cleared the message on the handset.
As i mentioned, if it happens again I'll try it to see if it works, until then I am not going to tempt fate.
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
