Question about DeLonghi RT400 Retro 4-Slice Toaster
After rwturning from vacation my rt 400 is full of indian mealy moths i have it in a plastic bag how do i clean it
Anonymous
I threw it in the garbage thanks for your so called help
Posted on Oct 16, 2009
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
How do i clean my air filter wr 400
remove the side cover
undo the nut in the middle and remove filter
take the foam of the frame
clean with a solvent, kero or similar
clean again in detergent and water
continue until spotless
let dry
use a air cleaner oil from a bike shop
put some oil on the foam and squeeze until oil is completly over filter( will be all the same color)
can do this inside a plastic bag to save the mess
fit back on frame
place a smear of grease around the edge that has to seal.
refit in air box, with centre bolt
feel all the way around to make sure it is sealing.
refit side cover.
doesnt matter too much if it is still a little wet
do this after every dusty ride
even twice on very dusty rides
I keep about 3-4 spare filters, clean in plastic bags, and wash them all together.
dont forget oil changes as well, they hold a bit over 1 litre, so change it often
Jun 16, 2010 | 2000 Yamaha WR 400 F
How to open the hard bags?
Put the ignition key in the lock, turn till the red locking plate moves, then lift both the plastic and the metal handle underneath
Jul 18, 2009 | 2004 BMW R 1150 RT (ABS)
WASTE BOTTLE FULL
yes - pull it out - twist the lock closed - tip upside down and shake it into a plastic bag - it will get awfully messy if you don't use the plastic bag.
Mar 25, 2009 | Konica Minolta magicolor 5430 DL Laser...
My vacuum puts out stinky air
We put small moth balls in our bag when we change it.
Jan 04, 2009 | Bissell 3522 PowerForce Bagged Upright...
Sub woofer full of moths...How do I dismantle it without damaging anything!
un do screws and then un clib it apart clean it vacum it maby add moth ball when done lol thx nick
Mar 13, 2008 | Harman Kardon SoundSticks II Computer...
DeLonghi RT400 Retro 4-Slice Toaster Logo
Top DeLonghi Kitchen Appliances - Others Experts
Paul Bade
Gerry Harvey
Gerry Harvey
ADMIN Canada
ADMIN Canada
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
