Question about Electrical Supplies
I disassembled my EM650 Generator and to clean out
I disassembled my EM650 Generator to clean out the fuel tank. After reassembly the generator ran with a higher RPM and has an unregulated voltage output. I tested the voltage with a Fluke volt meter and it showed 240 Volts+ then lowered the RPM and it then was putting out around 119 Volts. It seemed to vary directly with the RPM. Is my voltage regulator cooked?
Posted by timmseaton on
Anonymous
    Scholar:
  • 125 Answers
Most generators (except the latest inverter generators)
produce power directly dependent on RPM's.
The governor adjustment is critical.
This usually is in the form of an adjuster that through a spring, applies a preload to the governor arm.
The governor arm is attached to a shaft that disappears into the motor. Inside there is usually a set of weights that when spun faster will attempt to slow the motor and when spinning too slowly will attempt to increase revs. The adjustment you need to make is to the preload spring.
They are very sensitive to the motor being in good tune so do the air cleaner, spark plug etc before trying to get it right. Under voltage can do more damage than over voltage so take your time and get it to a good steady correct voltage with your usual expected load on it. A safety trip out box gives you a way to test voltage with a load on & some protection.
Work safe
Posted on Oct 15, 2009
Anonymous
    Champion:
  • 205 Answers
Fri st check your tag on the gen set. should read 3600 rpms at 60 hz. set your rpms so you see 120 volt no load. (this should be at your 120 receptacle). your RPM's directly affects your power out put. if your unable to maintain a steady power out put, call or take it to your local service shop to have it check and calibrated.
Ps906025 service manual? Carburetor issues. After bad gas with slugg ran thru, air fuel mixture is incorrect
If you didn't disassemble the carb and replace parts then your issue is a dirty carb. It had the right air/fuel ratio before and should afterward.
Disassemble and re-clean the carb.
Dec 01, 2017 | Homelite Portable Generator: 3000-Watt...
Have had generator in storage, Makita G1300R. What do I need to do repair wise to get it to start after about ten years in storage??
Remove air filter assembly. Disconnect fuel line from carburetor and drain old fuel into suitable container to discard. Fuel Shut Off in the On position. If fuel has gelled up in the tank or lines, add small amount fresh fuel in fuel tank, swish around several times and flush until clean.
Loosen and remove Carb Mounting nuts, throttle linkage and spring (note the position). Carefully remove Carburetor and very carefully remove gaskets (do not discard until completion of final reassembly)
Disassemble Carburetor and thoroughly clean with appropriate cleaner and immediately following with compressed air. If thick gelled old fuel is present, soak disassembled carb in cleaner overnight before using compressed air is highly recommended.Reassemble carburetor, replace gaskets and install Carburetor (Reverse dis assembly) Inspect and replace air filter upon reassembly.
Inspect spark plug and replace (do not over tighten).
Add fresh fuel and perform start procedure. Initial start might take a few pulls but should start right up.
Sep 23, 2014 | Garden
Where is the fuel filter
Either in fuel tank or built into carby
Jan 01, 2013 | Honda Portable Generator Model Ex1000
Homlite genorator surging when running 3000 watt unit
Is it a 3000 watt generator? Is it a generator running a 3000 watt appliance? Be more specific. What generator? What is it running?
First, make sure you fuel is fresh. Clean the carburetor thoroughly, that means take it off the generator, take it apart and clean all the little orifices, channels and jets of all the gunk a carb gets in it from sitting, bad gas and just because it is there. Reassemble and test it on the generator with fresh fuel.
Oct 30, 2012 | Electronics - Others
Coleman generator will only run smooth with the choke half on
Quite often related to restriction in fuel delivery. Start with checking in tank for debris and/or plugged screen to inlet for fuel line. Then check fuel line for kinks, collapsed, debris inside etc. If you have an inline filter, change it. If all's well to carburetor, then perhaps ports may be dirty, clogged. Easiest thing from there would be to add some fuel system/carburetor cleaner, maybe a little more than directions state, and run some of that through, mixed with some fresh,clean gas. Run until tank is 1/2 full or so, then allow to sit a day or 2 if you can. Then run again until tank close to empty, and add more of the mix and run again for a while, letting cleaner work through. You may end up having to have it disassembled and cleaned and repaired properly but, for the time and price of a bottle of cleaner or 2 , it's worth a try.
Nov 02, 2011 | Coleman Powermate Portable Generator...
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
I have a yamaha ef2000is generator that is 6 months old. After about five minutes the generator sputters like it is going to shut off but then revs up again and continues to run with constant sputtering....
Sounds like the carb is dirty. Try running the generator for a bit and when it sputters try slowly closing the choke to see if the generator will come out of its sputtering. If it does come out of it then you can start at the fuel tank and remove the filter screen in the tank and clean it well with an old toothbrush. If it is plugged with varnish it needs replaced. You can get by testing the unit by leaving it out and reassembling but you will need to replace it before actually using the generator. If the filter is clean check fuel lines for plugging and varnish along with the inline filter if it has one. If the lines and tank are clear you will need to pull the carb off, remove the bowl and clean the carb and jets. You may need to use a commercial carb cleaner if varnish is bad but be sure any plastic or rubber parts are removed before cleaning. Only immerse the entire carb if it is necessary. Try to remove the jets for cleaning. They can be a pain at times to remove but the jets and bowl are safe to immerse in carb cleaner. If the rubber o ring sticks to the bowl remove it before putting it in cleaner.
The reason choking the generator works when jets or fuel lines are plugged is because the choke blocks most outside are from entering the carb causing the engine to "****" harder through the jets in the carb.
Jun 30, 2011 | Electrical Supplies
I have a coleman Generator 1850. It stalls when i
Hello, I would check the carb for being dirty inside. It sounds like the needle valve is dirty, or not adjusted correctly, or there is rust in the carburator and any of these can cause the fuel not to feed into the engine properly. A good cleaning of the carb and proper setting of the needle valves should clean it up. Also check the screen in the fuel tank on the fuel valve.
Jan 21, 2011 | Coleman Sport 1850 Generator
I have a yamaha ec 5000 dve industrial generator that wont start. Its been sitting for about 6 years now, but it ran great last time it was used..
If it has been sitting to 6 years then the gasoline is no longer any good. Drain the fuel tank first thing. Remove the float bowl from the carburetor and drain the fuel and clean it out. Put in fresh fuel and try to start it. If it still will not start try using starter fluid to see if you can get it going. You may in the end have to disassemble the carb and clean it out.
Apr 21, 2010 | Tools & Hardware - Others
How do you start it cold
I always turn off the fuel and run my carburetor dry so the fuel will not go bad. If the generator has set up for anytime I will do a fast carburetor cleaning by removeing the float bowl and clean with carburetor cleaner as well as any line, port or oriffice then reassemble and start with new and clean fuel.
Oct 27, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
812 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
