Check the settings on the projector for the input video signal. There should be a couple of options: RBG and YPrPb. You are sending an RGB signal from the laptop and the projector is expecting YPrPb. Change the setting on the projector to RGB and the problem should be fixed.
Dan
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
