Question about Zebra Eltron P330i Card Printer
Keep getting broken ribbon message on zebra P330i printer
Hi there .. I keep getting broken ribbon message on zebra P330i printer. I also changed to a new ribbon, still getting the same error
Posted by vijeesh_vasu on
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
Zebra P330i out of ribbon error message but there is still plenty of ribbon
Send a command "!SA" The printes go recalibrate it self, don't forguet to put a card on the feeder.
Oct 26, 2010 | Zebra P330i Thermal Card Printer
Keep getting Out of Ribbon message even i changed ribbon..printer zebra p330i card printer. how can i fix it?
I assume you are using YMCKO ribbon rather that K monochrome. If using YMCKO (or a few other specialist ribbons) the spool has a large blue collar at the back with a paper covered chip. The chip has to be for the P330i rather that the Javelin or Polaroid version of the printer. The code on the YMCKO ribbon should be 800015-440. There are a number of companies selling cheap knocked off ribbons that claim to be compatible. That could be part of the problem. The printer has to communicate back to the windows driver when a ribbon is changed, maybe there is a comms problem, try another USB port or reload the driver.
Sep 18, 2010 | Office Equipment & Supplies
Out of ribbon p330i Zebra
possible need to recalibrate the sensors, go to driver, and send the command !SA.
May 06, 2010 | Zebra P330i Thermal Card Printer
I have Broken ribbon message on the LCD display. I just changed the ribbon and the clean cartridge. Hellp
It could be that the printhead is damaged or the ribbon sensor needs repair. Call Zebra troubleshooting for help. If it is under warranty you can send the printer back to zebra for repair. Takes about 3-5 days. All the info is on their website. good luck.
Jun 16, 2009 | Zebra Eltron P330i Card Printer
Card cutting ribbon on Zebra P330i
On the front of the head. 4 screws are there.
Near the head where the ribbon contacts the card.
Loosen the top 2. Let the metal guard slide down a bit. Tighten the screws. Try a card.
Keep adjusting the guard until you tune it right.
Sketchlab.com
May 13, 2009 | Zebra P330i Thermal Card Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Zebra Eltron P330i Card Printer Logo
3,121 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
