Question about Nikon D40x Digital Camera
D40 does not shoot on auto mode
My nikon d40 suddenly does not shoot on auto mode inside a room with low light. My room is lit by a flourescent lamp that gives enough light. But recently, when i put my camera on auto settings, it would not shoot. I no longer hear a whirring sound from the lens, meaning it does not want to focus. When i remove the flash, it shoots just fine. Is there something wrong with my camera? I didnt change any manual settings since I last used it.
Thanks for the help!
Posted by carissav on
Joe Hogan
  • 10,865 Answers
On the side of the lens check to be sure it is set to auto and not manual.
Posted on Oct 15, 2009
  • Joe Hogan Oct 15, 2009
    on the side of the lens check to be sure it is set to auto and not manual.
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
Jun 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
I have nikon d40, on continuous mode, auto, it doesn't shoot continuously. also, most of the time, it focuses but not shooting... please help.
I don't know what you are doing - mine shoots continuously with no problems. There is nothing to set other than to set the shooting mode.
I have noticed that some memory cards are so slow it doesn't allow continuous mode. I recently replaced mince ith 16G class 6 cards and they work fine.
Jun 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
May 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Black Photos
are you using the camera in manual mode (M)? try putting the camera in AUTO mode (the green icon)
Apr 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 dark pictures all of a sudden
Are you using the automatic mode or manual mode? Try checking the dial and see which mode you are using.
If you are shooting on the mode with the crossed-out flash symbol, flash will not be fired, and if there is not enough light, the outcome will be very dark
Dec 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
How do I get my nikon d40 to take Black white pictures?
You CAN!!! shoot in b/w with a d40, the only thing is you can't shoot in auto mode it has to be manual , aperture priority, or shutter prioirity. Go into menu - shooting mode - optimize image. you'll find it in there.
Dec 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Can't enable manual white balance and other options on nikon d40?
white balance can only be manually configured on "PSM" modes only, the other modes set the white balance automatically .
Sep 25, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
D40 manual mode takes "blue" pictures.
Go to Shooting Menu --> White Balance
Make sure this is set to Auto
Jul 05, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
Dec 09, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40x Digital Camera Logo
262 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
