How do i give a fax tone to a incomming fax
SOURCE: no incoming fax tone
Sounds like it's not set to auto-answer faxes. Do you have the manual so you can see how to check that setting? If not, I can try to find it.
SOURCE: not recognizing incoming fax
here is the manual go to the troubleshooting section
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=153e40d2e15d92515553420359e449b4&q=brother+2800+manual
SOURCE: how do you program the machine to recognize the incoming fax ring tone
if it is a sharp fax machine it has a reception button which you could change the status of unit from telephone to fax or answering machine. usually the indicator of these button is located on the rightmost portion of the lcd screen. once you press the reception button while the unit is on standby, the indicator will point on which of the three settings will you want to activate.
