I wouldnt bother going through all the hassles of trying to build one when you can buy one on ebay for a couple of pounds
heres an example...
http://cgi.ebay.co.uk/3-in-1-SATA-3-5-2-5-IDE-to-USB-2-0-Cable-Adaptor_W0QQitemZ360197061067QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item53dd6af9cb&_trksid=p3286.c0.m14
SOURCE: External Hard power is on but does not show up on my pc and does not seem to be running
Does it happen to be a Maxtor II? I had a very similar issue with my external and it devastated my backup program.
If the power light is coming on but not being recognized by the OS, your first step is (as you said) trying a different USB/Firewire cable. If that does not work and you don't care about voiding an expired warranty, you can open the case and remove the HDD. It will have several screws in the back; just undo them and slide it out. Try hooking the HDD up through IDE (or SATA if equipped) and after powering up, go into BIOS and see if it shows up on the IDE(SATA) list. If it doesn't, then as far as I know, your only other option is to try a pricey data recovery service.
