page numbers shown below. 2. Press and hold the TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO button you want to set up.
3. Enter the three digit code from the TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box, or Audio code list. Device Page TV 11 VCR 12 LaserDisc Player 13 Satellite Receiver 13 Cable Box 13 Audio Equipment 14 4. Release the device key.
5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat 2-4 using another code.
I had the same problem with my ILO tv, I found a code for Funai- manufactured by the same company. Unfortunatly I don't know the codes anymore, but I hope it helps.
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
