Question about AudioBahn AW1206T Car Subwoofer
I have a set of Audiobahn 15" subwoofers. No wiring diagram. I need help in assuring I'm not connecting wires the wrong way.
Posted by tac_talented on
Anonymous
  • 3 Answers
Crutch feild has a great wiring diagram section. www.crutchfield.com
Posted on Oct 14, 2009
How do you wire an audiobahn awis15j
I need to know how to wire my asi 15" subwoffers to my amp because theres 8 places to put wires on each sub.
Feb 27, 2012 | AudioBahn Car Audio & Video
How do i wire my 15 inch audiobahn AW1571T ?
  1. You can find a wiring diagram for your subwoofer and amplifier at the following website: http://www.crutchfield.com/S-jXlGCwReN8E/learn/learningcenter/car/subwoofers_wiring.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 19, 2011 | AudioBahn Car Audio & Video
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
How to wire post to post for 1subwoofer audiobahn aw1200n
depends on how you're hooking them up to the amp, and what type of amp it is you are using. but to wire them parallel, and drop the ohm rating, assuming it's a dual voice coil sub, you wire - to + on the sub, then - to the - on the amp, and + to + on the amp. Here's a diagram:ae0c628.jpg
Oct 07, 2009 | AudioBahn AW1200 Car Subwoofer
I have 15" audiobahn subs, but I need the right wiring
Contact company the can send you diagrams or go to a stero stop they should be able to help because some shop have wire diagrams for best way to get the most thump in you r trunk.Make sure you know the ohms your subs is 1-2-4 ohms.Should say on the back of your sub and how many contacts are on in two or four.
Mar 03, 2009 | AudioBahn AWES15P 15" Subwoofer Car...
I need wiring diagram for audiobahn AWES12P 4ohm speaker
you can go to audiobahns website. just fill in the specs like how many subs you have and what kind of amp/amps and it will give you all available wiring options.
Jan 26, 2009 | AudioBahn AW800 Car Subwoofer
How bridge the 15" 800 rms speakers audiobahn
parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Dec 16, 2008 | AudioBahn AWES15P 15" Subwoofer Car...
I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Nov 20, 2008 | AudioBahn Car Audio & Video
I need a wiring diagram
A wiring diagram for what?
Aug 19, 2008 | Car Audio & Video
HELP
hi there, do you have an amplifier to hook it upto mate? if you do its best to go into your local halfords etc and ask for a wiring kit for you car audio, or search on ebay, theyre normally around 20pounds. then it will come with instructions on where certain wires go etc, the 8 outputs are probably so you can connect two subs together. they should have a pos and neg on them somewhere. if you dont have an amp you probably need to buy one. if you have any further queries just ask mate
Nov 13, 2007 | AudioBahn AW1206T Car Subwoofer
AudioBahn AW1206T Car Subwoofer Logo
Top AudioBahn Car Audio & Video Experts
xxxxxx xxx
ADMIN Canada
ADMIN Canada
Trippy Tripp
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
