Question about Saws
How to remove stihl ts350 clutch - Saws
Posted by jimmy82 on
Anonymous
    New Friend:
How to replace a TS350 stihl saw clutch
Posted on Mar 14, 2011
Anonymous
    President:
  • 2,220 Answers
Remove the accessible parts like this:
R² Drive Link Inboard Clutch
Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
GL
Remove what remains like this:
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. HTH
Lou
Posted on Oct 14, 2009
How to remove clutch from Stihl fs81 brushcutter?
go google and type in --workshop manual for Stihl brush cutter model fs 81 -- and download the pdf version from the stihl site
Feb 08, 2016 | Stihl Garden
I have a dewalt d28710 metal chop saw which blows the 13 amp fuse in the plug when I press the trigger to start cutting , anybody else had this problem ?
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Dec 03, 2013 | Saws
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Need repair manual for stihl ts350 super
Download Link:
Jul 05, 2012 | Saws
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Why won't my Stihl TS350 Cutoff saw go to full revs? It starts well.
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Dec 11, 2010 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
I have a Stihl TS350 demo saw that a family member gave me. I used an inline spark tester and it's getting a week spark at tester, but nothing at the plug(old or new plug). I took off the flywheel, and it...
TS350's got electronic ignition after serial number 13927613 early 1985 - yours must be earlier than this, possibly European specification. Before messing with the point gap, try cleaning the contacts with 'wet and dry' type abrasive paper....tear off a strip and fold double along long edge so that abrasive is on both sides (you could use a fine nail file/board) and pull through closed points so that it cleans up the oxide coating that builds up through non use. Finish off with a dab of electrical cleaner or similar 'safe' solvent (brake and clutch cleaner) and maybe a shot of air.
Nov 04, 2010 | Garden
I have a stihl ts350 demosaw I'm not getting any fire
Follow the two wires and look for scuffs broken or worn insulation. Sometimes easy to find by turning off the garage lights and pulling the rope (arcs can be seen easier this way). The wires use common ground to kill the spark through the switch. These wires are known to wear through the insulation after years of use and they inadvertantly ground out the ignition coils. Repair the wires with heat-shrink tubing or electrical tape as needed. Or replace the wires entirely if they are in very poor condition.
Hope this is helpful,
Dolf-
Nov 10, 2009 | Garden
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
