Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag LSE7804ACE dryer, has a terrible noise when you start it, and than shuts off
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
Depending on what kind of noise you are hear it could possible be the motor if you hear a low grumble sound. This could be from a bad start relay on the motor and wont allow the motor to run. the start relay is no longer available but the motor assembly can be purchased, part number 306055. However if the noise you are hearing is a banging noise this could indicate an entirely DIFFERENT problem such as your rear roller bearings that the drum rides on. part number for both is 303373.
Posted on Oct 14, 2009
How to replace dryer belt on stacked Maytag washer/dryer?
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck. You can also access the information by part & those parts usually have installation videos.
Jun 21, 2015 | Maytag Washing Machines
How do I fix gas clothes dryer? It makes a terrible noise.
that is a sign the bearing are going out. letting drum rub the sides
Feb 25, 2015 | Maytag Dryers
Maytag LSE7804ACE - Dryer works fine, but every time I pull the knob to start the washing machine, it pops the breaker and it wont start. Any suggestions or ideas?
Sorry but with such a fault it is extremely difficult to diagnose especially remotely ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB or main motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Apr 04, 2011 | Maytag LSE7806A Top Load Stacked...
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
Loud Rubbing noise from my Maytag Performa Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
Need a belt routing diagram for maytag lse7804ace dryer , repaced the drum rollers, belt came off of motor pulleys, can not get on correctly.
not sure how to help u if u have a local appliance parts store in town they would b glade to help u on the back of dryer belt pagages there is a sample haundi24
Oct 27, 2009 | Washing Machines
The dryer on my maytag stacked combo lse7804ace the motor works but the dryer doesnt spin. Broken belt?
You will need to either re-install the belt or replace it. I would assume that it's broken because it's not that common for it to just run off the pulleys.
Oct 19, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
453 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
