You can link up to 10 devices on the Parrot MKi9200.
If you link an eleventh phone, the kit displays “memory full” You then have to delete one of the linked telephones. To do this:
1. Press the knob and select Settings > Bluetooth > Linked devices.
2. Select the telephone(s) that you no longer need.
3. Select Delete
Let me know if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
Still , check :-
Go to select Settings > Bluetooth > Linked devices
Ho many telephone(s) you would see?
Let me know, once checked!!
Thanks!!
OK!!
Try some tricks :-
1. Just turn on
the parrot device and press down the red and green button at the same
time.
2. Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
3. Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Check and let me know, if this works unless i would find some more tricks.
Thanks.
The step i offered to you is listed in FAQ there. This shows they are aware of the problem. The Other tricks, i collected it from my database which is a combination of User Reviews and Feedback.
The other reason what i suggest would be a Faulty Component. This is the only reason if it would be show such erratic behavior. There are electronic items and it would hardly take a sec for them to act Stupid. So, just chillz out and use some tricks which is given by other Users.
Thanks.
I only paired the Samsung Renown to the Parrot. No other phones are paired but still getting the "Memory Full" Error !
Only see the (1) phone..............Samsung Renown, however the check box preceeding the displayed phone is NOT checked & unable to be checked !
Will try the tricks later when I get home tonight. In the meantime,
1) Why does the Parrot not ask for a PIN # when pairing the Samsung renown ? Tried pairing a Motorola KRZR and it asked for a PIN #.
2) For both phones (Samsung & Motorola), when depressing the Green phone key, there is no audible queing. The Motorola was previously paired to the Parrot for several months and after the phone was deleted from the Parrot, adding the phone back did not restore functionality. When pairing the Motorola, received the "Memory Full" error also, but it asked me for a PIN #.
3) Tried resetting the Parrot to Factory settings & the system just cycled forever.... spinning circle arrow; and process never completed.
