Question about SanDisk Sansa e200 MP3 Player
My sansa e200 is not getting detected on my computer though its showing in device manager that the drivers are not installed . i tried re-installing the drivers but of no use. what to do? Also qhen I unload transk they donot appear in the Sansa
Posted by carol_burgos on
Muntejaya Ginting
  • 10,422 Answers
I cant get in my computer but its showing in device manager
As you tell the device in can only be detected in the device manager.
It can not be seen as a removable disk in MSC mode and neither in MTP mode, showing as media player with the Sans icon.
Consult next page about 'player not being recognized':
http://kb.sandisk.com/app/answers/detail/a_id/42/kw/manager/r_id/101834
Refresh the drivers or manually ad the driver for the player as described.
Sansa manual for e200 series (version 2):
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
Important:
1. Check the system requirements of the computer as described in the manual on page 8 of the file [=page 5].
2. Charge the device using an USB connector directly to the computer,
not through a hub or card reader, preferred at the back side.
If more help is needed, just post a comment.
Sep 28, 2009 | SanDisk Sansa e250 MP3 Player
Doesnt show in my computer
check the usb drivers by clicking start> right click on my computer >system >hardware>device manager
(in vista just type it in the search bar)
and check the usb drivers by clicking universal serial bus controllers and check if they have an ! sign.
if they do uninstall them and click scan for hardware changes and install the usb drivers again.
If this doesn't work, uninstall then install the usb drivers using the motherboard cd.
or try it to another pc if it works.
or ask for a refund or repair(if it is in warranty it's free)
Jun 22, 2009 | SanDisk Sansa e200 MP3 Player
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
Computer wont recognize sansa fuze
STOP EVERYTHING ALL YOU HAVE TO DO IS TURN OFF YOUE SANDISK, THEN plug it in!!.
Feb 01, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa e280 mp3 player stopped working i dnt knw y
I'm unable to assume the exact problem with your mp3 player as you've bluntly said that the device is not working. Try the following steps and that should work. If not let me know:
  SOLUTION 1 - Reset the device
Resetting the Sansa View/Fuze
Resetting the e200/c200 series
SOLUTION 2
 - Reload and update to the latest firmware
STEP 1 - Enable MSC or Recovery mode
Enable MSC mode on e200v2 / c200v2 / Fuze
Force Recovery mode on e200v1 / c200v1 / e200R / View
STEP 2 - Update to the latest firmware
You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware
Sansa Fuze firmware update
Sansa View firmware update
Sansa e200 series firmware update
Sansa c200 series firmware update
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 31, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e250-MTP Driver
MTP driver kit is located here.
MICROSOFT
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Can you fix my sansa e200
hi
    Are u able to see the Sansa player detected under mycomputer
or whether is it getting detected under device manager. once i tried connecting sansa device in msc mode it got detected under device manager so i was able to reinstall its driver u can also try that
also respond to my email address at [email protected]
Oct 13, 2007 | SanDisk Sansa c150 MP3 Player
My computer wont detect my e200
Dont turn it on and plug it in. That had happened to me and that fixed it.
Aug 31, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
128 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
