Question about Hotpoint Washing Machines
Washer will not empty its water -hotpoint washer
Washer will not empty its water hotpoint washer dryer wd440
Posted by danjoanne443 on
Jack Hunter
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 139 Answers
Chec to see if the water pump is plugged with lint or some othe debris
Posted on Oct 14, 2009
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Wd440 not drying. how does the fluff get emptied?
Because it is a washer dryer, there is no fluff filter to clean.
It is self cleaning, because the fluff is washed away by cold water entering the condenser and flushing the fluff away.
Trust this answers your query.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Washing Machines
Hotpoint Washer/Dryer,Aquarius WD440 will not take softener.
take out small either blue or green filter from detergent drawer where you would normaly put the liquid softner and run it under hot water tap my guess is that the small pipe within is clogged this should clear it
Oct 13, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
